Question about Dishwashers
Indesit DG6100W problem...please help!
Hello! hope someone can help. i have an indesit DG6100W dishwasher. I turn it on, it goes half way ish through the cycle then just sticks and doesnt carry on! how can i fix it?? any ideas??? someone mentioned i should do a reset on the timer - how on earth do i do that!!!
hope you can help! thanks!
Hi, I have the same dishwasher and it fills from the cold supply, not the hot and it doesn't have a cold cycle as is previously suggested, as you will know kellyemb :-)
The Indesit DG6100W does a fill from the cold and heats as it washes, so if it's sticking part way through, it could be the heating element. Have you tried opening the door when it sticks and seeing if the water is hot? The heating element went on ours and it kept tripping the electric whenever the it tried to start to heat the cold water. If it is the element, they don't cost much to replace, even cheaper if you know someone who can fit it for you! Ours cost us around £12 and hubby fitted.
The only other thing I can think of is it might be the timer, like someone has suggested but how to reset it, I have no idea. I have seen on another website that a replacement timer is around £55 plus VAT, which is a little expensive.
Hope you get it fixed.
Posted on Oct 04, 2008
Try selecting a cycle that doesn't heat the water. (quick, delicate, china etc.) Don't use a sanitize, hot wash, hot rinse or heated dry option either. When a dishwasher trys to heat the water it pauses the timer until the sensor is satisfied. It continues to wash/heat. Another possible problem , Run the water at the sink until it is hot before you start the machine. A dishwasher isn't capable of heating cold water. It is just designed to boost the temp of hot water. If it completes the cycle this way, the sensor is bad not the timer.
Posted on Jul 05, 2008
Need manual for indesit dishwasher d1620 please
Visit this link to download the Dishwashers DI620 User Guide (pdf format)
Hope this helps (remember to rate this answer).
Jul 07, 2011 | Indesit 24 in. DI67 Free-standing...
Loud Buzzing noise
Sounds like something may have got past your filter and is touching the main pump impeller eg piece of broken glass or piece of plastic.I,ve even seen a spoon touching the impeller. You may have to take the bottom off the machine and remove the pump if you can,t see anything under the filter,Hope this helps. Regards Stefan.
Jul 08, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit DG6100W dishwasher will not work
It sounds as though the micro-switch inside the lock mechanism is displaced.
Undo the 6 screws at the top of the door (on the inside) and remove the outer pane. This will give you access to the lock mechanism. Please switch it off first.
The micro-switch can then be adjusted so that when the handle is released, the switch engages (you should hear a very soft click).
Hope this helps.
Jun 20, 2009 | Dishwashers
I HAVE A LG DISHWASHER IT ONLY GOES THROUGH HALF CYCLE AND COMES UP WITH HE?
Hello jaq1407Welcome
You said, You HAVE A LG DISHWASHER IT ONLY GOES THROUGH HALF CYCLE AND COMES UP WITH HE?
Please send me the model number and year!
Waiting your response
Oct 22, 2008 | Dishwashers
Indesit idl 705
you may be in "flood mode". there may be a leak into the base. or your bottom base hoses may be blocked, best get someone in who is able to strip a d/w base out.
Feb 08, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Door catch plate Indesit d61
undo the screws at the top of the front door and puul the control unit out this gives you acsess to the door catch which is quite simple to replace be careful the stainless steel is quite sharpe
Dec 03, 2006 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
750 people viewed this question
Top Dishwashers Experts
