Question about Dremel Variable - Speed Multipro Rotary Tool 395
We own a homelite chainsaw. The chain continues to turn after the trigger is released. Help?
  • Anonymous Dec 16, 2008
    I have the same problem. The saw runs and then the chain starts turned even though I haven't pulled the trigger. Can you be more specific? Thanks!
  • 62 Answers
If it idleing down and still turning loosen the chain a bit and oil the clutch
Posted on Sep 12, 2008
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ... > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Looking for homelite model 3374 chainsaw
Pull the handle back to free position.
Jul 12, 2014 | Homelite Garden
My Homelite 46 cc 18" chainsaw has a very high idle. How can I fix that?
Turn the idle speed screw (not the H and L jet needles) CCW until the chain stops turning, but the engine continues to run. Hope this helps!
Jul 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 09, 2010 | Homelite ZR10926 16" Chain Saw
Carburator adjustment for Homelite xl 12 chain saw
Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should get the engine running if it will. If it does not, check the lower diaphragm on the carburetor for hardness or cracking. You appear to be running on prime only--the carburetor doesn't seem to be pumping in fresh fuel. You may need to do a carburetor clean and re-kit. Check the fuel line condition and the fuel filter in the tank for plugging. Make sure the muffler and air cleaner are not plugged. Once you get the engine to continue running, warm the engine up. Open the throttle and adjust the H needle CW--the engine should start to speed up, but still 4-stroking. The proper setting is 4-stroking, but immediately 2-stroke when cutting. Release the throttle and adjust L needle CW so that the engine runs fairly smoothly, yet will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Apr 17, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
Sep 09, 2009 | Homelite Garden
Do not know how to start my chain saw
First the chain should be tightened properly before starting. When you pick up on the chain midway of the bar it should pull away from the bar about 1/4". The proper mix of oil & gas in the fuel tank & Oil for the chain in the oiler tankk is needed, If so, locate the on/off switch & turn it to "on". Pull the choke lever out. Depress the throttle trigger & engage the latch for the trigger. With the saw held firmly in place, pull the starter rope until the engine hits. Then move the choke to half & pull till it cranks. move the choke lever to the run position.
Aug 19, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Chain brake will not release (homelite chainsaw)
The header says you have a Homelite saw and if this correct you can go to and look up parts or other information that you might need for your saw. There is also a contact us area. Good luck
Jan 25, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Dec 29, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
65 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
