Question about Fisher Scientific Freezer Isotemp* Plus 13-986-142
-80 freezer noise and battery
Hello, we purchased a -80 freezer, it is making too much noise, inaddition, the alarm battery says alarm battery low,
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
I have a fridgerdire freeze that has not beem used in a a while. We plugged it in today and I have a power light and a temperture alarm. When I turn the freezer on I hear a buzzer alarm going off and the...
Hi James.
Most Kenmore upright freezers use a backup battery located at the lower part of the appliance. When the battery is low the freezer will beep continuously. If the unit has been off for a long time, and if the unit uses a battery, then the battery may need replacement.
Here a picture of the battery in its housing, located in the lower front part of the freezer.
Feb 19, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer Alarm keeps going off...
I think your freezer's coils have been damaged. Consult a enjinner.
Aug 10, 2009 | Kenmore Freezers
The alarm keeps going off. Food is frozen fine just alarm
That alarm is there for a reason. Grab your owner's manual and see the different things it can mean. If the gas is getting low, that could be it, and you'll want to solve it as early as you can.
Sometimes a power surge or brown out can make that alarm go off. Try unplugging it for 5 minutes.
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore freezer depleting 9 volt batteries, setting off alarm
trojo50,
your defrost elements are not working or the water inlet for the evaporator tray is clogged. That alarm is to let you know something else has triggered it. This could be s imple DYI solution or require a service call. let me know if you are up for the DYI.
randy320sgi
Feb 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
temperature of the food rises to a level unsafe for long-term storage, the buzzer will
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm
without the alarm sounding.
Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch.
If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and
seals properly. If you suspect a technical malfunction, call an authorized servicer
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fisher Scientific Freezer Isotemp* Plus 13-986-142 Logo
62 people viewed this question
Top Fisher Scientific Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Fisher Scientific Freezer Expert? Answer questions, earn points and help others
