Question about Whirlpool LSB6200KQ Top Load Washer
Howling or squealing noise when the machine is filling with water
We have a Whirlpool toploader 12 years old that is making a howling noise when it is filling with water. It would seem there is some restriction that has developed causing the noise. I believe that the water is filling slower as well. Any thoughts??
  • Anonymous Mar 17, 2014
    after pressing start button does not fill; no obstruction in water lines; also makes noise (seemingly from below,0 of money loose in a dryer
There is a restriction in the valve assembly. it is servicable so remove it, open it up on both hot and cold and clean thoroughly. replace and test
Posted on Jul 15, 2008
Mvwc300vw0
The howling (squealing) noise is likely the belt, if I had to make an educated guess. Of all the fixes you could be stuck with, that's one of the easier ones.
The reason I suggest that is because even though it probably isn't washing to its fullest potential either, you wouldn't really notice it, if it's still able to do a little agitation. Once the spin cycle kicks on, the motor applies a lot of power, and if the belt is loose, it'll spin that belt around the wheel, creating a really soothing and serene squealing noise, causing average humans to start seeking sharp objects with which to slice their wrists.
Sep 02, 2012 | Maytag Washing Machines
Our Whirlpool makes a howling noise
Hello-  Debris in sump can cause noise, but if unit is 5yrs or older, motor bearings are failing. Part about 100$. Have installation instructions if needed. Let me know if this info helps -have more if needed. -Thanks-ED
Mar 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Howling noise
The inlet valve is not open or closed all the way. Repair will run you around 120. If you need help puting one in, let me know. good luck :)
Jul 12, 2009 | Whirlpool GSC9455 Top Load Washer
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Howling noise
I don't see anything located directly behind the icemaker on this model. Try to better isolate the location of noise if you can. If the icemaker is at fault, I wouldn't bother trying to repair. Order another one. One other thing to check is the water flow. When the noise happens again, stick your finger in the ice mold and feel for water. If it just filled, then problem may be in the water valve. Hope this helps,
Oct 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Howling noise/squeal
sounds like your differential carrier needs to be shimed,common when changing ring and pinion
Jul 22, 2008 | 1985 GMC K1500
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
209 people viewed this question
Dan Webster
Dan Webster
Sal De
