Agfa SnapScan Touch Flatbed Scanner
Problem for Agfa SnapScan Touch Flatbed Scanner
Scanwise X Software problem on Mac OS X
By iDeedy on Jul 01, 2008
When launching Scanwise X I get the error message "Scanwise cannot find the current ColorSync system profile. Please recalibrate your monitor or select another System profile with the ColorSync Control Panel". When I go to the Color Sync Control panel my Scanner isn't listed under devices. I have had the scanner working previously on this computer and I have tried reinstalling Scanwise.
Comments:
Jul 02, 2008
- I think the ScanwiseX software isn't installing properly although I did have it up and working a few weeks ago.
Jul 02, 2008
- I have tried following advice babout reinstalling but still cannot see Snapscan in my ColorSync Contol panel.
Solution #1
posted on Jul 01, 2008
Somewhat Helpful)
battlesmith
Rank: Wiz
Rating: 82%, 125 votes
hi,
please check whether you have installed the software in Administrator mode only because it can restrict you in establishing the connection..Also try to restart before you reinstall your Scanwise..hope this helps you..thank you!!..
Solution #2
posted on Jul 02, 2008
Not Rated)
maklean
Rank: Guru
Rating: 86%, 641 votes
Try download driver from link below:
http://www.driverskit.com/freedownload/Scanner/Agfa/SnapScan_e20_ScanWise_2_0_0_9-e20/14055.html
See if Your System Needs Driver Updates
Solution #3
Not Rated)
IrishDruid
Rank: Guru
Rating: 88%, 1790 votes
Could be that there is a software conflict that is causing this issue. Uninstall the software and any other scanning software you may have through Control Panel. Next, go to the manufacturer's website and download the latest version of the software for your OS.
You may also want to try using a different cable, in case that is the issue.
Comments:
Jul 02, 2008
- If you are having issues with the current software even after replacing the cable, try this software and see if that helps. Make sure you uninstal the current software first, to avoid conflicts:
http://www.hamrick.com/
Solution #4
Somewhat Helpful)
hemantraj
Rank: Wiz
Rating: 75%, 196 votes
uninstall your software completely, and then restart your pc, after that re install the software .and check now whether you can see your device in your sync control pannel
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Popular Solutions for Agfa SnapScan Touch Flatbed
Questions and Unsolved Problems for Agfa SnapScan Touch Flatbed
Do you recommend Agfa SnapScan Touch Flatbed Scanner?
Answer
Answer
I am operating an agfa snapscan touch (serial #55a9n0miu) and Mac 0XS 10.4.11. The computer says... (More)
Answer
Agfa Snapscan Touch scanner will not run on my new computer with XP operating system. Is there any... (More)
Answer
Is my Agfa ScanWise from 1999 compatible with windows xp?
Answer
I tried to open my scanner but get a message after it warms up A communication problem has occured. ... (More)
Answer
how do start the agfa snapscan touch flatbed
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Agfa SnapScan Touch Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
