Question about Maytag Dryers
I have a 5 year old gas dryer part number MDG5500AWQ that will not stay lit. I have taken the front off and cleaned around all the components then started it. The ignighter lit the gas for about 30 seconds then went out. The dryer then came back on in about 2 min. then out again. The dryer does not seem to stay hot (or even warm) and the cloaths take very long to dry. I also cleaned the exhaust and even disconneced it to see if that helped. Nope. thanks, Bruce O'Brien
Great job Great service... No more soggy socks! thank you, Bruce O'Brien
Posted on Jul 04, 2008
Have Maytag gas dryer model DG412. Ignited glows, will light gas, but then gas shuts off after a minute or so. Replaced the solenoids, didn't help, same thing happens. Gas ignites, but quickly shuts off....
if the flame goes out fast like that the dryer has to be cleaned out and also check the vent line,all a dryer does is move air if it's blocked and can't move air the flame won't stay lit.that's a gas dryer it should be taken apart once a year and cleaned so this doesn't happen and also so you don't have a fire.check the duct where the lint filter slides into and you can remove the vent line from the back of the dryer,if the gas stays on then you know the block is in the vent line.make sure there isn't a cage outside or a birds nest isn't in the vent these are common things that happen.
Nov 12, 2017 | Maytag Dryers
Dryer 2 months old. Made a pop noise and stopped working on the count down. Won't restart. Panel is lit but the dryer won't function. Ideas?
Likely either a fuse or component on one of the control boards went. At 2 months old, why waste your time? Call for warranty.
Aug 01, 2015 | Maytag MGDE251YL Front Load Gas Dryer
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Maytag Dryer runs for 8-10 seconds then shuts off accompanied by burning smell
When you say it runs for 8 - 10 seconds, do you mean it spins for that long or the flame is lit for that long?
Dec 01, 2012 | Maytag Neptune MDG9700A Gas Dryer
Gas burner won't stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Dryers
Dryer is leaving brown marks on clothes. it is either a burn mark or they are getting caught between dryer drum and shell, not the door
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Steve
Mar 29, 2010 | Amana ALG331RAW Gas Dryer
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
Neptune won't dry clothes -
I would replace the solenoids. The gas valve is not fully opening. The glow bar may be failing but the coils on the valve are in need of replacing..
Eric
Sep 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
May 06, 2009 | Whirlpool LGR5636L Gas Dryer
Dryers Logo
101 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
