GE Spacemaker JVM1540 Microwave Oven Logo
Posted on Dec 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sparks coming from inside of oven body - GE Spacemaker JVM1540 Microwave Oven
Anonymous
Level 2:
New Friend:
  • Expert 144 Answers
  • Posted on Dec 15, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
144
Questions
0
Helped
30446
Points
450
Microwave ovens usually have a small panel inside that looks like a piece of card. This can sometimes decompose and cause sparking . If so then you can replace this easily. You should be able to get one quite cheap.
pete
2helpful
When i use the microwave it makes a very loud coughing and spluttering noise and there is a flashing of lights inside. It also smells of smoke. Any help greatly appreciated. I live Bristol, England if they...
proceed according. God bless youIf you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
1helpful
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
see the guide for test the magenetron and another component.
Sparks when starting then goes to pause mode
see this next steps. God bless you
1helpful
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
2answers
I heard a pop and then i saw sparks inside the oven, the sparks were coming from what looks and feels like a paper cover inside the microwave
This sounds like the inner lining is coming off and alloying the metal interior to spark. You will need to repair the liner and this should fix your problem.
Sparks in microwave/convection oven
Remove the plate and clean it with warm water
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
1helpful
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
2helpful
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Problem
check halogen light holder and connections, and any damage body, check inside body of microwave oven , because of microwaves some sparks comes from damaged body..
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
