Question about HP Officejet 6310 All-In-One InkJet Printer
Cartridge error Tells me to extractleft side cartridge and to reapply but i have no luck because problem remains
  • alcocer Aug 26, 2008
    cartridge error: cartridge on left is not intended for this printer
  • 40 Answers
Try to clean the copper contacts of the printer in the left.before you clean the contacts unplug first the power cable..after clean the copper contact go ahead and insert the ink cartridge..if the issue still remain/occur the printer needs to be repaired/replaced...coz it is now a hardware issue
Posted on Sep 01, 2008
ESP9 cant move Ink cartridge, stuck on left
unplug for 1 min, after reapplying power it may reset itself
Oct 08, 2014 | Kodak ESP 9 All-In-One InkJet Printer
I have a lexmark printer model 5495,it tells me that the right cartridge is incorrect, i just put in new cartridges in . the cartridges 28-black/29-color, it still tell me the samething
Hi, The Right Cartridge Incorrect error message generally indicates a communication error between the All-In-One and the cartridge. This can be due to a faulty cartridge or to a simple interruption in the communication between the cartridge and the All-In-One. The procedures below will help you identify the cause and resolve the issue.Lexmark uses, at least they used to, a chip in the ink catridges that verifies that the ink catridge is Lexmark and hasn't been refilled. There are ways around it, which is why third party cartridges work. Yours may not have been reset or damaged when refilled. Follow the below steps: 1) Disconnect the power from the printer.
2) Remove the black power brick/block from the rear of the machine. (It may be a little tough to pull it out the first time you remove it.
3) Open the top of the printer/multi-function unit.
4) Gently pull the ribbon in order to center the printer cartridge carrier.
5) Open either the left or right side and remove the cartridge. (Depends on which side the error is occurring on, black on the left, color on the right)
6) Verify that all of the plastic strip that covered the new contacts on the cartridge have in fact been removed.
7) Wipe both the cartridge and printer contacts with a dry, lint free cloth.
8) Wipe the bottom of the cartridge with a damp, lint free cloth in order to verify that the ink is flowing and looks correct.
9) Make sure there is no water remaining on the cartridge.
10) Re-insert the cartridge into the carrier and make sure that it is bottomed and inserted all the way to the rear of the carrier slot.
11) Re-insert the power brick/block.
12) Re-connect the printer power cable.
13) Power on the printer and the error should be resolved.
14) Run the print alignment and print or copy several pages to insure the problem has been resolved.
IF YOU NEED TO BE WITH THE ORIGINAL CATRIDGES PLASE FOLLOW THE BELOW STEPS.
ALWAYS PREFER LEXMARK CATRIDGES FOR LONG LIFE OF PRINTER
  1. Remove the indicated print cartridge.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridge.
  6. If the error:
    • Does not reappear, the problem has been corrected.
    • Reappears, replace the print cartridge with a new one.
      BESTWISHES.....
Dec 19, 2010 | Office Equipment & Supplies
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
Instead of changing black toner printer (samsung clp-510)is giving error INVALID TONER BLACK
This can happen if you install a CLP-500 cartridge OR a Xerox Phaser 6100 cartridge.
Physically they are the same, but the 'chip' is different.
In the case of the Xerox, it is the programing of the chip that 'tells' the printer its a Xerox cartridge, and the printer won't accept this as valid.
If it's a CLP-500, the three contacts on the side of the cartridge have a resistor (for the capacity of the cartridge) and a falmeproof fusible resistor which resets tha page counter (for that cartridge) when a new cartridge is installed.
Oct 15, 2009 | Samsung CLP-510 Laser Printer
Ink cartrige dell 1110
Maryfrancesh
Exerpt taken from Dell Laser 1100 User Manual (p30)
1 Open the front cover.
2 Pull the used toner cartridge out and lift it up and away from the printer.
3 Unpack a new toner cartridge. Hold the cartridge carefully and gently shake it from sideto-
side 5 or 6 times to distribute the toner.
4 Pull the tape to remove the protective paper.
5 Locate the cartridge slot inside the printer, one on each side.
6 Unfold the toner cartridge handle and grasp it. Insert the cartridge into the printer until
it snaps into place.
7 Close the front cover. Make sure that the cover is securely closed. If it is not firmly closed,
printing errors may occur.
PDF Manual can be found here -->
http://support.euro.dell.com/support/edocs/systems/1100/en/OM/OM_1100_en.pdf
The guide also contains pictures of what to do.
Andy
Jan 29, 2009 | Dell 1110 Laser Printer
Constantly getting error code E3 on my Pixma MP150 multi-function printer. Have checked inside repeatedly and can see no paper jam
What may have happened is that the Paper sensor is locked down and tells the printer that there is paper in the path (although there isn't any). The paper sensor is a toggle switch and there is a paddle that pushes it down as the paper goes in/out. Look on the right side of the unit ,under the roller assembly. Sorry, but I do not have a service manual for this unit.
Error list :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | Canon Office Equipment & Supplies
Printer will not work. Error E3
Error list :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
Thanks, Joe
Nov 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Dell 1710
If that is the only light:
Remove the toner cartridge and firmly shake it from side-to-side and front-to-back several to use the
remaining toner, and then reinsert it and continue printing. Repeat this procedure multiple times until
If not let me know.
Nov 16, 2007 | Dell 1700n Laser Printer
Page count unreasonable
Re you using genuine HP NEW cartridges? If not, you must make sure that whoever has re manufactured the ones you are using has replaced the chip on the cartridge. This tells the machine how many copies are on the cartridge.
Nov 14, 2007 | HP LaserJet 2550L Printer
Toner Notice
Oct 30, 2007 | Dell 1700n Laser Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
153 people viewed this question
Seeker5211
Seeker5211
