Question about Sony KDL-32M3000 32 in. LCD Television
My Sony Bravia is stuck on channel 2 and won't respond with the remote or the top of the set channel changer.
I have the same problem. I have the Sony Bravia KDL-40S4100. I can't get it off channel 2. It won't work with the remote, and it won't work on buttons on the top of the console either. The power button on the remote is still able to turn the TV on and off, but aside from that, everything else is frozen.
Posted on Feb 02, 2011
  • Wayne Lee Feb 02, 2011
    My Sony Bravia KDL-40S4100 has the exact same problem being stuck on channel 2. The only button working is the green on/off button on the RC. I don't know what to do.
  • Lonnie Larivee Feb 02, 2011
    Okay, I finally emailed Sony and they said to make sure that the "channel fix" is unchecked on the tv's menu. I had found this 'channel fix' before and ignored it because I thought it meant to 'fix' the channel, as in if it was BROKEN...lol It actually means the OTHER 'fix" which is to make it STABLE or FIRM or in this case, STUCK on channel 2. Duhhhh......
    So I went in to the tv's menu and found "Channel fix" (can't remember exactly where in the menu it was, but it's there), UNCHECKED it, and PRESTO, tv remote worked again!!!!!
    So go find that stooopid "Channel fix" and UNCHECK it, or turn it off, whatever....lol
SOURCE:
I have a strange problem that I can't find any other reference to.
Two possibilities.
  1. The corrupted Firmware.
  2. Main system control IC fault.
Remedy
  • Firmware update
  • Replace the main system control memory IC.
Jun 22, 2015 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
Why does my Sony Bravia get stuck on channel 6.1?
Try a reset to this set and check. If it do not help you, the main system control IC is faulty, and should be replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 16, 2014 | Televison & Video
My sony bravia klv40ex600 won't turn on,the light indicator for power,volume and channel is on, the screen is still black
Hi, have you tried pressing the TV button that is under the On/Off button on top right hand side of remote control? Some times its possible to accidently press the DVD or VCR controls and this by-passes the TV as a remote?
Another cause can be a poor or low battery in the remote itself. If you have no luck let me know & we can try some more things, however, I have heard that The On/Off Switch on the TV can be a problem. Goodluck, Jon..
Jul 22, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Need to program my synergy v time warner remote to my sony bravia 32"
STEP 1: PRESS THE MODE BUTTON ON THE TOP OF THE REMOTE, THEN PRESS TV STEP 2: PRESS AND HOLD THE "SEL" BUTTON AND THESH "MUTE" BUTTON AT THE SAME TIME UNTIL THE BUTTONS ON THE TOP ARE LIGHTING UP IN SEQUENCE FROM RIGHT TO LEFT STEP 3: HOLD THE CHANNEL UP BUTTON UNTIL YOUR TV TURNS OFF. WHEN THE TV TURNS OFF HOLD THE CHANNEL DOWN BUTTON UNTIL YOUR TV IS BACK ON AND ALL LIGHTS ON TOP FLASH AT THE SAME TIME
Jul 18, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How do a program or scann the channels in my sony bravia t.v?
If you're referring to the KDL-40V2500 TV, please refer to the page number 37 in the manual to Auto Program the TV.
Press the MENU button on the Remote. Then, select the ANALOG SETUP SETTINGS.
Then, select the AUTO PROGRAM under the ANALOG SETUP SETTINGS.
Jun 13, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Remote Codes for new Sony Bravia
you should press 10000, which is the code
Mar 06, 2009 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Sony 37" Flat Panel Bravia--cant change from channel 2?
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
Jan 05, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony KDL-32M3000 32 in. LCD Television Logo
2,900 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
