Question about IBM ThinkPad T30 2366 Notebook
Remove hard drive
How do you take the computer a part to get at the hard drive. we have removed evry screw we can find.
  • johnpage1 Dec 26, 2008
    I have a T30 IBM laptop I want to remove the hARD DRIVE AND REPLACE IT WITH ANOTHER I TOOK OUT ALL THE SCREWS and don't see how to get it out. Help
For a T30 Laptop remove the single recessed screw nearest both edges of the bottom, front, left. Near the RAM cover plate.
Remove the battery
Open the LCD screen
Gently pull the bezel assembly with the 3 round audio jacks.
The IBM/Lenova site has a service manual you can download.
Ref    t30enstg_67p4720.pdf
Posted on Jul 07, 2008
Smart hard drive failure
First get a suitable type of drive which will have be SATA and make sure you have completed a backup of pics, music, favourites and documents also a valid copy of Windows or recovery DVD
1. Position the computer with the front toward you.
2.Remove the two Phillips screws that secure the hard drive cover to the computer.
3. Lift the left side of the hard drive cover swing it to right, and remove the cover.
4. Remove the three Phillips screws that secure the hard drive to the computer.
5. Use the plastic tab to slide the hard drive until it disconnects from the connector, then lift the hard drive up and out of the computer
6. Remove the 4 screws on the cage that holds the drive in place note which way the drive sits in the cage.
7. Is reversal of taking drive out
Oct 05, 2013 | HP Compaq Presario CQ40-330TU
Replace hdd
turn off the computer and unplug from wall
open the case/tower
remove wires from hard drive
remove screws from hard drive
remove hard drive and replace with new hard drive
replace screws
replace wires
close up the case
turn on the computer
Does that help?
Dec 27, 2012 | Computers & Internet
How to clean the fan of my computer
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or you might want to remove it to get it clean
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
Oct 20, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
How to clean the fan air
or Remove an HP Presario C500 Fan Assembly to clean it
Hope this helps
How to remove hard drive from acer aspire x3200
Remove the cover/side panel on the case to get access to the components inside the computer.
The SATA hard drive is secured to the disk drive bay with 4 screws.
Unplug the SATA data cable and power cable from the hard drive, then remove the 4 screws securing the hard drive in the drive bay.
The hard drive can be removed from the drive bay.
Reverse this order to fit the hard drive back inside the computer.
Oct 05, 2012 | Acer Aspire X3200 PC Desktop
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
Aspire one can not detecthard drive
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can work with the help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computer main-board as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
Oct 15, 2011 | Acer Aspire One PC Notebook
How do i remove a harddrive from a computer case when only one side has screws to remove? Details: Okay so i'm trying to remove a hard drive from a computer case that only has screws on the back right...
In this case the hard drive is mounted in a frame. Look for mounting screws that locks this frame to the computer case. When you remove this frame you can access the screws holding the hard drive.
Jun 12, 2011 | Compaq Computers & Internet
How to remove hardrive from ml3109
Turn the laptop so the bottom is facing up. Make sure you have powered the laptop off and have unplugged the AC adapter and battery. Near the part labeled E there are two small phillips screws. You would need to remove those and the tray at location E will pull out with the hard drive attached. There will be 4 screws(two on each side) holding the hard drive onto the tray, remove those and the hard drive can now be taken out. Reverse the steps using the new hard drive.
Mar 05, 2011 | Gateway Computers & Internet
How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Nov 03, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
IBM ThinkPad T30 2366 Notebook Logo
806 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
