Question about Insignia Digital-to-Analog Converter for Analog TVs
No signal after autoscan for channels
We have magnavox DTV Digital to Analog converter (STB) and followed the directions as close as possible. ( We use RF cable). When we came to do the autoscan part, there is a box saying no signal. We are not sure what we ought to do with channel. Do we add all numbers or just one number? It asked for the main channel, is that we add just # 3 for the main channel? Hope we can get it through with your help.
Thanks,
Mary
  • 6 more comments
  • krausmal32 Jul 23, 2008
    Thanks for the help. But even I tried with our main channel - 3. Still no service. Will try to use electric rabbit ears. Thanks. M
  • rach84jo Aug 30, 2008
    The Magnavox converter is a dud. RCA got great ratings but stores were out of them and the experation date for the $40 coupon was the same day of purchase, so I had no choice but to get the Magnavox. It just doesn't work.
  • ragtimedog Sep 14, 2008
    I have the same problem with not only the Magnavox, but another converter box as well. If I shut off the box, I get my regular channels, unless I unplug the antenna. I'm using the electric rabbit ears too.
    I didn't understand the solution.
  • abooley Oct 03, 2008
    I followed the instructions for the Magnavox TB100 MW9 dtv converter box only to end up with no signal. Is there a special antenna I must purchase? What kid of antenna wire must be used. I have an analog tv currently.
  • rkorsen Oct 05, 2008
    I went through the setup with the TB100MW9 several times which also resulted with the same "NO SIGNAL" message. I only received channel 58 which is transmitted 6 miles from here. I am using a rooftop antenna and RF cables that currently provides excellent analog free tv on all channels. I also tried to move the antenna to different positions and retried the scan with the same results. Also tried a rabbit ear amplified antenna and then no longer received Ch. 58. I found it interesting that the converter indicates it is finding various channels during the scan by blacking out the box, but then fails to show the channel.
  • kymi83 Nov 06, 2008
    i'm having the same problem, but i have a RCA, i've heard great reviews about them, but yet i still get the box saying i don't have signal. What type of antenna am i suppose to use to make this work. All this seems to be so much more trouble than it should be. It's just a big headach, someone please help.
  • jojones787 Feb 17, 2009
    I hooiked up the converter box and it didn't work. I called the support #, they said, with a digital TV [I have an outside antenna] I did not need the box. When the channels converted this morn I had only a blue screen. I hooked up the box, reset my channels in the TV, and still nothing. What is wrong?
  • Anonymous Feb 19, 2009
    no signal after autoscan for channels
Tv stations main channel is an addition of 1 (04-1) but can have up to 5 stations (4-1, 4-2,4-3,4-4,4-5). They may not have anymore then one, it is their choice. PBS usually has 2 or 3 channels
Posted on Jul 09, 2008
NO CHANNELS
What specific model of JVC multi-system TV do you have? What is the signal source?
The majority of the JVC multi-system TVs that I've researched only have analog tuners (NTSC, PAL). The AV-29LX is an example of the older JVC TVs. Since most over-the-air signals are digital, you will need a digital-to-analog OTA signal converter to watch any signal from an aerial TV. If you have a cable system that has upgraded to digital cable, you will need a cable box.
Converter boxes are harder to find but there are a few remaining. Here's one for the US: http://www.amazon.com/Magnavox-DTV-Digital-Analog-Converter/dp/B0013ZKZGU .
I wish that I had better news for you.
(A few low-power stations still broadcast in the analog format. However, you have to be really close to the station or have an outdoor antenna to have a chance at receiving the signal.)
Mar 30, 2014 | JVC 29" Flat Screen Multisystem TV
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Is a booster needed for the tb100mw9 dtv converter box?
Best solution would be to use an outdoor antenna with an amplifier(booster)--but in some areas you may get by with an amplified set top antenna. Just all depends on your location..
In perspective, I have an outdoor UHF dish and 10 foot VHF antennas with an amplifier and still i get only fair reception on outlying digital stations that normally come in clear on analog.
Also--this converter box must complete the autoscan with an antenna attached, or else you'll receive NOTHING; not even by manually selecting a known digital channel.
This #@!! box automatically locks out what it considers to be unused or weak channels. It makes the decisions and you're left with 'no signal' messages and nothing to do but try a rescan.....and you cannot add channels to any it has already found.
Feb 02, 2009 | Insignia Digital-to-Analog Converter for...
Setup Magnavox DTV Digital Converter can only get Channel 10
Missing or poor antenna connection to converter.
Feb 17, 2018 | Televison & Video
DTV converter box
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
Oct 18, 2008 | Insignia Digital-to-Analog Converter for...
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
491 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
