My tall Cinni standard fan isn't working. When you switch it on you can hear the motor trying, but the fan blades don't move at all. It's boiling today in my office, so we'd like to know what might be up so we can fix it asap.
Stage 1: unscrew 2No. top and bottom nut/bolt put to one side, lift 4No. hinge clips and remove front cage.
Stage 2: partially unscrew spindle screw on fan body then slide fan off spindle.
Stage 3: plug in fan turn to setting '1' (lowest setting, the motor will hum but not rotate) now with a hammer 'carefully' tap the spindle so that it is aligned within the housing, it may need to lo left, right, up, down whatever direction it needs to sit centrally withing the bushes of the front and rear housings. Then tap the end of the spindle which sometimes re-engages/realigns the spindle within the rear bush.
Stage 4: reverse of stage 2 & 1
Good luck
Posted on Jun 29, 2009
Broken cinni pedestal fan
rattling fans are an indication of unbalanced fan blades. check for dirt or corrosion on blades Remove the blades and see if the motor still vibrates. If so scrap the unit. You may be able to get new blades but as few places carry fan spares I would hold out hope in that department. Check around the appliance repair shops and see what info you can dig up . May be a contact to the manufacturer on the web will give some answers as to spares
Jul 14, 2013 | Cars & Trucks
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Our hampton bay fan has stoped spinning but lights still work, why would the fan itself all of the suddent stop working? thanks
    One of the biggest problems I have encountered with ceiling fans has been the wearing out of the manifold, the rubber device that holds the fan blades to the motor. I have never seen them fail where all blades fall off at the same time, but I guess it is not impossible. If this has failed the blades would still be hooked to the outer ring, but not move even when the motor runs. If you can hear the motor running and the blades are not moving it may be the manifold. If the motor is not running it seems obvious that it is a motor problem or a motor controller/remote controller problem. Not easy to repair.
    Aug 29, 2010 | Dryers
    Remote control works the light on my Hunter ceiling fan but blades do not move
    Can you hear the motor run even though the blades are not turning? If so, the manifold/flywheel may be bad and perhaps have broken away from the motor shaft.
    Aug 28, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
    The fan blades do not turn but the fan motor can
    speed switch is no good, the one attached to the pull cord. replace
    Jul 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
    Blades will not turn
    The motor probally damaged while you are moving the fan to the new house.
    Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
    3 speeds settings - only 1 speed and that is fast
    I believe that your fan speed selector is bad.
    Jul 02, 2009 | Heating & Cooling
    I would advise taking the fan cover off and the blade off of the motor and cleaning it. (Make sure its unplugged when you do this.) Maybe hair and dust has gathered around the motor and the blade. This would make the motor have to work harder, especially if stuff is wound around the motor. Good Luck.
    Apr 16, 2008 | Dryers
    The power is in but the blade wont move
    Your best bet is to UNPLUG the fan, remove the protected cage and the cover that protects the motor and take a can of compressed air and blow out any dust that you happen to see that has built up in the fan. Then look for a bushing that is towards the front of the shaft and the rear of the shaft and place a drop of 3 in 1 oil where the bushings are located. I would place a couple drops on the front and rear shaft, spin the shaft by hand, move it back and forth, then then put it back together again and try it.
    This should extend the life of your fan as long as the motor isn't burnt up, and the fan hasn't been left on for a long period of time when the blades where not moving.
    Hope this helps.
    Keep in mind.. a little maintenance goes a long way.
    Dec 04, 2007 | Honeywell HS1750 Stand (Pedestal) Fan
    Heating & Cooling Logo
    639 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
