Question about IBM Infoprint 1532 Laser Printer
Disabling Power Save mode
I have a 1532 that has problems coming out of the power save mode. Is there any way to disable this option. I know you can set some of the other models 1332 to =0 to disable.
  • 32 Answers
If you enter the config menu, you can turn off energy conserve. You enter the config menu by turning off the printer, holding the center and right arrow, and powering the printer on. Continue to hold the buttons until you see Performing self test. Then you will see config menu. If you scroll down to energy conserve and select it. You can change the option to off. This will disable power saver.
Posted on Jul 24, 2009
My monitor states its in power save mode.when i press any key,nothing seems to happen.
To bring the computer out of the power save mode press the "Windows" key once and release, wait one second, then press enter. The system should come out of power save mode. The Windows key is the key with the Microsoft Windows Symbol on it. Another solution would be to disable power management.
To disable power management, right click on the desktop, click on properties, screen saver, then Energy Savings Settings button.
Change all the settings to "Never", then click on "apply" and "ok". Power management has been disabled.
Apr 29, 2010 | Dell E173FP 17" LCD Monitor
Tip
Resolving intermittent Windows USB device issues
PROBLEM: USB Devices (Both internal and external) work intermittently.
DISCUSSION: Issue is caused by Windows power management disabling the USB Root Hub to save power (This option is on BY DEFAULT in all Windows installations)
RESOLUTION: Open Device Manager, scroll down to the USB Root Hubs Listings (There may be as few as two most I've seen is 7) Right click each hub, select Properties on the drop down menu, then click the POWER MANAGEMENT tab. There you will find a check box to allow windows to turn off this device to save power. Uncheck the box and close the window, repeat on remaining USB Root Hubs, then reboot.
This will resolve most intermittent USB device issues.
on Dec 03, 2009 | Computers & Internet
The pc entering in pwoer saving mode and
  1. Start or restart your computer.
  2. Press the F10 key when the F10=Setup message is displayed.
  3. Select the appropriate Language option.
  4. Select the Power menu.
  5. Select (if not already selected) the Energy Saver item.
  6. Press the Enter key.
  7. Select Advanced .
  8. Press F10 to save the change.
  9. Select Power > Timeouts > Hard Drive Timeout > Never .
  10. Press F10 to save the change.
  11. Select the Power > Energy Saver .
  12. Press the Enter key.
  13. Restore the desired Energy Saver Mode (Disable or Minimal).
  14. Press F10 to save the change.
  15. Select File > Save Changes and Exit .
Feb 03, 2010 | HP Compaq d530 PC Desktop
My monitor says going into power save mode and goes off. The computer tower is still powered up and the power light on monitor blinks. when I press the power button on momitor it says monitor working check...
Disable Power Management on Windows 7 or Vista If you are using a desktop computer, chances are that you don’t want the computer to go to sleep automatically. This is even more the case if you are running Windows 7 or Vista in a virtual machine for testing purposes.
Disabling Power Management in Windows 7
Start by clicking on the power icon, and open up the More power options:
sshot-2009-10-21-23-05-42.png Under the “Additional plans” section, select High Performance, then “Change plan settings”:
sshot-2009-10-21-23-06-52.png Then change everything to “Never”, and save the changes:
sshot-2009-10-21-23-07-41.png Disabling Power Management in Vista
Disabling power management is simple and easy. First go to the start menu and click on the Control Panel.
Click on the System and Maintenance link:
vistacontrolpanel%5b1%5d.png Then click on the Power Options link:
poweroptions%5b1%5d.png Then select High Performance:
highperf%5b1%5d.png This will disable the automatic sleep mode, but will still turn off the display. You can click on Change Plan Settings to disable that as well if you want.
Jan 26, 2010 | Hannspree HANNS-G 19" Widescreen Monitor
Unable to disable power save mode
Press the power button, the option to disable power save is on that menu.
Nov 04, 2009 | Cell Phones
I have hp pavilion dv4 laptop . The wifi is disabled by itself!
At the time when laptop is charging, go to power settings and disable the battery (energy) saving option, as this option starts to switch off devices one by one to prolong the discharge time.
Aug 07, 2009 | Computers & Internet
Power save mode
I had the exact same problem but it is fine now! :) And this is how you solve it .....you press the power button (single press), and a series  of options come up...if you scroll down them you will come across a 'deactive power save mode' option, click select and this should sort it out!
Hope this helps! :)
Jan 15, 2009 | Nokia N96 Smartphone
Lexmark 1532
If the Operator Panel is locked. (Menu's disabled) you need to enter Config Mode to enable the operator panel. Press and Hold the > right arrow and down arrow buttons while powering on the printer. Once in configuration mode scroll to Panel Menu where you can enable it. Exit Config Mode or just power the printer off and back on.
Mar 28, 2008 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Laser Printer Logo
349 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
