Dell Vostro 1500 Notebook Logo
Posted on Dec 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, my dell 1400 DVD/RW drive is not detected and can't be opened. When i restart, the lights(LED) blinks a few times like normal. This means that the drive is getting power. How ever, it is not detected in windows. I'm using Windows 7 64-bit.
Anonymous
Level 2:
New Friend:
  • Expert 188 Answers
  • Posted on Dec 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
188
Questions
0
Helped
57046
Points
270
It could be a hardware or a software issue
First run a hardware test on the computer, follow the steps
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
Then if there is any part defective replace it.. Else reinstall the OS to fix the issue
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Won't turn on but amber stand by light is lit.......
FULL 'make model (what it is)' in all questions first 3 words.
How to fix a computer that won't turn on and has a blinking ...
Quora https://www.quora.com > How-can-I-fix-a-computer-that...
Dec 25, 2018 - A blinking orange light on a computer typically indicates that there is an issue with the power supply or motherboard. Here are a few troubleshooting steps you ...
7 answers · 17 votes: I need help my desktop computer shows orange light when opening up
Why can't my desktop power on? The orange light is ...
Mar 18, 2021
Why won't my laptop turn on even though the orange ...
Mar 30, 2023
Why is my check engine light on in the on position ...
Feb 8, 2020
Why do traffic lights in some countries (like the UK ...
Feb 25, 2017
More results from www.quora.com
Blinking amber power light - Won't turn on.
Dell https://www.dell.com > desktops-general-locked-topics
Apr 5, 2013 - If the power light is blinking green - The computer is in standby mode. Press a key on the keyboard or move the mouse to resume normal ...
6 answers · 0 votes: Hi, Welcome to the community First thing you can try is to reseat all devices inside the tower. ...
Computer won't turn on, solid orange (amber) light
Sep 27, 2013 - Disconnect any external peripherals (flash drives, printers, external hard drives) from the computer including the power supply. · Press and hold ...
2 answers · Top answer: Hi BC Taylor, Please follow the below shared instructions to identify the point of failure. ...
LEDs
IBM https://www.ibm.com > docs > SSYSP8_5.3.0 > r_coss...
Amber if the system is in standby. Green if the system has full power. Module Fault LED, Amber indicates a fault in a PSU, cooling module or SBB I/O module ...
How do you remove the solid Amber light showing o - Q&A
Best Buy https://www.bestbuy.com > site > questions > question
Jan 13, 2021 - Settings > System > LED Indicator > Voice detection status When you toggle on/off, it will either turn on the amber LED indicator or off. I ...
My cd/dvd burner won't work. i put in a cd and a green light blinks a few times and nothing happens. My Dell is a dimension E520. thanks!
In MY Computer, check to see if the DVD drive icon is there.
Try a different DVD or CD brand
Check the sata or IDE cable connection to the rear of the drive and also the security of the power rail
3helpful
My vostro 1400 laptop does not detect the battery
hi, gmotian:i think the battery does't match your laptop,i suggest you buy a new one battery from http://www.adapterlist.com/dell. which is an online shop,exporting various models replacement laptop battery.best luck!
1helpful
Dvdrw can not detect in dell astro 1400 notebook
Check your system BIOS whether it is Detected there, if no, Shutdown your system, Press your CD-Rom drive towards the system firmly (Incase its making a partial contact), and restart your system. If Yes, then Start your system, Right-Click on my computer, go to properties, Device Manager, DVD/CDRom Drives. and click on it. if your CD Rom Drive is not detected there, then on the Device Manager Screen, click on Action, Scan for hardware changes, your system should detect it automatically. But if its already there, right-click on it, Uninstall it and do the scan system for hardware changes again. It should solve the problem like that.
PIONEER DVD-RW DVR-106D will burn but won't read
i have the same problem ,but when i restart my pc ,i put the disk it can read without a doult .The problem is your disk drive can't read disk when it on windows mode ,using dos and it just fine,some kind of trouble appear cause i burn too much disk in a time and it can't read next time i open computer .May be your windows problem just restart wins then put the disk in ,if it appear the green light it mean it's reading then the green light off it's mean it had identify the disk and does read it
2answers
Dell Dimension E510- Trouble Reading DVD/DVD-Rom
open the pc and check the IDE cable and power cable for this drive if you only have 1 drive then the jumper should be on master . CD-rom drive and DVD-rom drive should connect to master on the jumper, CD-RW and DVD-RW should connect to slave on the jumper that if you have 2 drives on your pc. If you still have problem after you checked all these cable and jumper connection than problem maybe inside the drive check it open the drive to see if there is nothing stuck inside the drive and clean the laser light.
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Dvd-rw is not being detected by bios
try the following
1.reseat the odd..u can find the steps at the below mentioned link
http://support.dell.com/support/edocs/systems/ins6400/en/om/parts.htm#wp1076794
2. reset the bios to defaults
3. remove the upper and lower filters
the registry path is
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
plz let me know if it helps so that we can check further possibilities and do rate the solution
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
