CD/DVD drivers deleted from registry?
Hi! Recently purchased a toshiba laptop from best buy and while trying to delete a program, we think the CD/DVD drivers got deleted. Now the pc is not showing the CD drive, even when a disc is put in it. Is there something we can do from home to fix this or do you recommend taking up to our nearest geek squad? Thanks for any help you can give us!!
  • Heather05 Jul 01, 2008
    I forgot to mention that the drive is a Pioneer drive...idk if that helps at all.
    Sergeant:
    Champion:
  • 244 Answers
It's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
http://support.microsoft.com/kb/314060
Posted on Jul 01, 2008
I use Samsung R 248. Recently my dvd drive is not working. It can't read any cd or dvd. what should I do?
Try to delete the upper and lower filters in the registry.
) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned.
Apart from this, make sure that the driver is enabled.
Thank you!
Feb 22, 2011 | Samsung Computers & Internet
I havea toshiba l355-s7915 laptop.the cddvdw ts-l633a will not work.i tried to update the drivers.no luck!i uninstalled it,turned off the computer,and turned it back on.no luck!the device manager said the...
You restore the vista
Follow the bellow link
http://www.askvg.com/how-to-restore-reinstall-all-uninstalled-desktop-gadgets-in-windows-vista-and-7/
If the problem is same please do next.
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
You also go run type %temp% and enter
Delete all temp file and restart,
If same as before ,do the next,
You can try this trick - It might work - But, only if this is the root cause of your problem:
Many third-party programs that control CD or DVD burning (as well as some player applications) install CD- or DVD-ROM filter device drivers into Windows. These filter
drivers are meant to allow for low-level hooks into the hardware, to allow for functions such as packet writing (where a CD-R/W or DVD-/+RW can be written incrementally,
like a hard disk).
First Backup the registry.
Step 1: Start Registry Editor
type "regedit" in the Start Run box.
Step 2: Delete the UpperFilters registry entry
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the details pane of Registry Editor, on the right side, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
* If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
* If you do not see the UpperFilters registry entry, you still might have to remove the
LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
6. On the Edit menu, click Delete.
7. Click Yes when you receive the following message:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed.
1. In the details pane of Registry Editor, on the right side, click LowerFilters.
Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can
find more solutions or more help on the Microsoft Web site.
2. On the Edit menu, click Delete.
3. Click Yes when you receive the following message:
The LowerFilters registry entry is removed.
4. Exit Registry Editor.
Step 4: Restart your computer
Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the
problem is resolved. You can reinstall your CD or DVD writing or recording software.
Several of the products made by Roxio are infamous for causing this problem, although in fairness to the company the most recent versions of their Roxio CD/DVD writing
software (6.2 and higher) do not have these problems. Users of 5.0 or 6.0 editions of the Easy CD & DVD Creator product, which has been bundled with many new PCs in
the past, should upgrade to 6.2 or better. Other programs can also cause this problem, with the same solution.
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled.
Hope this helps,
Jan 21, 2011 | Toshiba Computers & Internet
My Toshiba CD-RW/DVD-ROM SD-R2102 cant read any cd buy there is a power and can detect my bios
If same as before
Follow the link
http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
like a hard disk).
Hope this helps,
Jan 12, 2011 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Got an error code 39 on my laptop what does it mean
error code 39 is:
Windows cannot load the driver
The driver might be corrupt or missing
suggests re-installing correct drivers
Sep 12, 2010 | Toshiba Computers & Internet
D: Toshiba DVD-ROM SD-R2102 ("Write error - Medium error")
Yo' Sam!
Start by checking your WINDOWS CONTROL PANEL. Be sure there are no errors for your drivers. IF you have your proper drivers for your DVD Drive, totally remove ALL drivers and then restart your system... still have problems?
Next TOTALLY DELETE your Roxio program... somewhere on the Internet there is a tool that will do just that. You want to try your best to CLEAR and ALL hard drive and REGISTRY traces of ROXIO program(s)!
Just ONE bad ROXIO/REGISTRY problem can have you chasing your tail for days/forever.
With ROXIO deleted, try one of the FREE DVD burning programs to assure it's not really a DVD problem?
I just did a GOOGLE check and there are tons of hits for you.
Hope this helps!
Anthony
Apr 16, 2010 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Eror code 39
this can help you http://support.microsoft.com/kb/314060
Nov 24, 2009 | Toshiba Satellite L355D-S7809 NoteBook AMD...
Dvd driver of toshiba
THere is no need to get DVD drivers as they are included in standard windows package and are integrated.
In case you have windows Vista installed and dVD is with exclamation mark in Device manager you jut need to delete upper and lower filters in regestry.
Click Start, click Run, type regedit, and then click OK. Registry Editor starts. (In Vista, right-click Registry Editor, and select Run as Administrator)
In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear.
To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Step 4: Restart the computer
Important: If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Sep 14, 2009 | Toshiba Satellite A105 Notebook
My Acer Asprire 5100-5674 no longer recognizes the cd/dvd drive.
hi, cd drives do wear out or just break, most time it is software related. but they can just stop working.hope this helps. good luck
Feb 26, 2009 | Acer Aspire 5100 Notebook
Laptop
I recently lost my CD/DVD drive when I (correctly) uninstalled a Roxio application from my Toshiba laptop. After a week of frustration, I finally found the fix. My CD/DVD drive is back!
Go to the Windows START menu.
Click on RUN and enter: regedit
FOLLOW THIS TREE:
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
In the CLASS folder, look for:
Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
Value Data: [Delete All Value Data from UpperFilters and LowerFilters] You will see the upper and lower filters folders once you get to the end of the tree… *\*\*\control\class
If a backup folder for either the upper or lower filter folders shows up, clear all the data from these folders as well.
Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
Exit Registry and Reboot
Nov 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite notebook dvd/cd player
Try to get an Windows XP or Vista CD.
Boot the computer with the cd on drive.
Be sure to select to boot from CD in setup(F2 key I think) or boot menu (F9 key I think)
If the computer boot from CD, probably you have a software problem, else your drive is damaged.
Good luck.
Dec 19, 2007 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
