Question about Dell Latitude D600 Notebook
Dfdsaf SAD Asd DSA
  • 2,028 Answers
Be more specific please?
Posted on Jul 07, 2008
No power going to the fuel pump
first check all fuses.
well if the security lamp is on, and the IMMobilizer light glows
it will never run. (by design) (2 seconds max)
so are the lights glowing?
no power going. (when,)
did you read the FSM on the staged events to get engine started.
my wild guess? (sad i have to ask) is it wont start?
1: IMMO not active
2: battery charged volts near 12.6vdc rested.
3: starter cranks fast. and ASD closes
4: ASD relay sees good spark and CKP, and CMP sensors.
5: engine starts, if #4 is good then it sustains running.
if not ASD drops out in 2 seconds. killing INJECTION.
it cuts the fuel pump too.
the PCM will throw a DTC error code (did you scan it cranking ??)
for if the ASD fails to OUTPUT 12v. at step 3.
the PCM closes it, then looks, and if output is bad, it ends this event and logs the failure..
to check the pump , it takes 2 people
one at the key, and one at the pump wires.
or you WILL miss the 2second event.
one way to avoid all that is to hold finger on the ASD relay
and keyon and see if it clicks closed.
if not ., no need to check pump ,its LAST in the chain,
if the ASD clicks and drops out, during that click the pump does run
for 2 seconds, min.,
if the ASD is dead, check the PCM control line to the ASD for
making coil energized in the ASD relay, (12vdc across it for 2seconds)
if the coil is energized, and the DTC throws, for bad ASD , it is.
if the ASD goes, hot only for 2 seconds, again use any $9
scan tool to see the error.
here is the scan too tests. most books forget.
1: scan tool connected.
2; Crank engine for 5 seconds, (min)
3: release key. BINGO, the ECU tells you why the ASD dropped out.
eg: ASD error, CMP error, CKP errors or others (spark?)
does RPM read near 250rpm cranking? on the scan tool?
Is TPS throttle angle near 100% (cutting fuel) ? bad tps. (cut wires)
fixing cars without a $9 scan tool , as sold on feabay is 100x harder.
get the tool and use it.
they rent them cheap or loan them for free.
not to be confused with a code reader, which are near useless.
Feb 11, 2014 | 2004 Jeep Grand Cherokee
Volvo V40 Stall when foot off pedal and DSA light on
needs a throttle body cleanin--idle air motor maybe aging--get car scanned soon--mite also hav a vacuum leak--get a repair manual for troublshoot procedures
Oct 30, 2011 | 2000 Volvo S40
Need the region code for my toshiba Studio E160 Copier printer.
It depends on the model you have:
Model Code Paper Tye
NAD 1 LT Series
Important: When FAX kit (GD-1061) is not installed, do not input code except 1 or 44.
Hope this helps, it comes from the service handbook.
Apr 23, 2011 | Toshiba E-Studio 160 All-In-One Laser...
Cheats in benten vilgax attack
Pause the game and enter the following codes in the Cheats menu for the desired effect:
  • xlsmoothyBig Smoothy
  • herotimeFull Upgrades
  • everythingproofInvincible
  • portalSkip to the next scene
  • hudToggles the HUD health & energy
  • generatorUnlimited Ben10 Alien's Energy
  • primusUnlock all 10 aliens after Ben loses them
Apr 12, 2011 | Sony PlayStation Portable (PSP) Console
Amber light is on
Download IBM DSA software from ibm site or google it and install it.
From the report you can analyze the issue
After install
click start > all programs > Ibm DSA > IBM DSA
This will automatically run and collets hardware logs.
Find the logs on c:\ibm_support\
Analyze it
Mar 08, 2011 | IBM System x3200 M3 7328 Server tower ...
Cannot Open DSA.MSC file error
When you install the Administration Tools Pack on a computer that is running Windows XP Professional x64 Edition, the Active Directory Users and Computers MMC snap-in file (Dsa.msc) is installed in the %windir%\Syswow64 folder. Additionally, the computer's file system maps the Active Directory Users and Computers MMC snap-in to the following path: DriveLetter:\%windir%\Syswow64\Dsa.mscHowever, the Active Directory Domains and Trust MMC snap-in incorrectly specifies the path of the Active Directory Users and Computers MMC snap-in as follows: DriveLetter:\%windir%\System32\Dsa.mscWhen the computer's file system tries to locate the Dsa.msc file from within the Active Directory Domains and Trust MMC snap-in, Mmc.exe is run. Mmc.exe is run because the Dsa.msc file is associated with Mmc.exe. When Mmc.exe is run, it uses the following path to locate Dsa.msc: DriveLetter:\%windir%\System32\Dsa.msc DomainPathAfter the Mmc.exe command is run, the Active Directory Domains and Trust MMC snap-in tries to locate the Dsa.msc file. Because the Dsa.msc file does not exist in the %windir%\System32 folder, the error message that is mentioned in the "Symptoms" section is generated.
To resolve this problem, manually copy the Dsa.msc file from the %windir%\Syswow64 folder to the %windir%\System32 folder.
Your hardware manufacturer provides technical support and assistance for Microsoft Windows x64 editions. Your hardware manufacturer provides support because a Windows x64 edition was included with your hardware. Your hardware manufacturer might have customized the Windows x64 edition installation with unique components. Unique components might include specific device drivers or might include optional settings to maximize the performance of the hardware. Microsoft will provide reasonable-effort assistance if you need technical help with your Windows x64 edition. However, you might have to contact your manufacturer directly. Your manufacturer is best qualified to support the software that your manufacturer installed on the hardware.
For product information about Microsoft Windows XP Professional x64 Edition, visit the following Microsoft Web site: ( For product information about Microsoft Windows Server 2003 x64 editions, visit the following Microsoft Web site:
May 30, 2009 | Microsoft Windows Server Standard 2003 for...
DSA-3100 certificate
Make the certificate as trusted on your network. Then you will not be seeing these kinda message
Nov 25, 2008 | D-Link Airspot DSA-3100 Firewall
Active directory
we have a following command option to open active directory:
Sep 30, 2008 | Microsoft Office Outlook 2003 for PC
Dell Latitude D600 Notebook Logo
198 people viewed this question
Alun Cox
