Question about MSI KM4M-L Motherboard
Sound my onboard sound does not work any ideas?
  • 983 Answers
Check the onboard audio is enabled or not in the bios setup ...
if disabled then enable it ...
i think you might not have installed the audio codecs ... just install the audio codecs ....
the audio drivers contains the audio codecs so just try installing the audio driver from your manufacture cd ....
if already installed then just reinstalling it ...
this solves your problem
if you still persist the same problem then may be the capacitor near the audio port is blown off just try to identify it...
check is there any burning smell or burnt mark near the audio port..
replace the capacitor if so ...
this must solve your problem ...
any doubts you can reply me
i am always here to assist you
thank you
bye .....
dnt forget to rate the solution ...
Posted on Jul 01, 2008
Windows 7 64 bit upgrade then sound doe,s not work tested speackers and connections any ideas
See my previous post here: http://www.fixya.com/answer/answerpageslideview.aspx?thid=24854933&ctg=26&p=2
Your mixer: Right-click on the sound icon. Go through the menus--see which sound system currently is configured for use: Is that correct? (It's likely that the onboard sound ports are enabled by default. Thus, you can't get sound through your sound card, instead.)
Another option, perhaps, is HDMI. A video card featuring an HDMI port--or onboard video circuitry featuring an HDMI port--passes through both High-definition video--and, audio! Such config also proves available in the mixer, as well. Again, invoking such circuitry requires making that default (or otherwise usable) in the mixer.
I prefer to make every sound config option visible. Two sets are available in the sound icon mixer (from Windows)--those for "Play" and "Capture" (recording or monitoring). Check every box for each set to make their options visible and perhaps usable.
So, you wish to use your C-Media card!: It's likely then that disabling the onboard sound circuitry and ports may help. Using both proves still perhaps possible. Nonetheless, driver conflict also is possible. Have you checked device driver for driver conflicts and function? (Device Manager in Control Panel.) Any missing drivers, or codes indicating failure?
To disable onboard sound, go through your BIOS menus and find the one which enables onboard sound--click or "Tab"/"Space" to disable. Then, tab or click, navigating to the last menu. Indicate "Yes" in the option that saves your new BIOS configuration and reboots. (A less desirable method is to disable the onboard sound circuitry in Device Manager--found in Control Panel.)
(To get into BIOS config--turn on you or shut down and restart your machine--press the "Delete" key--well before the hard drive and OS boots. A newer BIOS allows mouse navigation and clicking to change config--older ones require the keyboard and use the "Tab" key to navigate. The "Space" key on the bottom of the keyboard allows assent to change an option.)
Check out C-Media's driver config icon program--in Control Panel (perhaps available in the task tray, as well). Is configuration accurate? Testing your speakers here also proves possible--that's very useful as you tinker.
Try upgrading the driver--with a correct download from C-Media's site or directly from right-clicking in Device Manager. (Recently, C-Media set up an easier to use site--one which doesn't require registration and joining.) The driver disk you note can't be updated--it may grant you function initially, anyway, though. (Config likely is similar or the same.)
Alternately for Windows, one may obtain third-party driver update software--online or on a disk. This sometimes proves more accurate than device manager--Microsoft often doesn't care always about noting and downloading the most current drivers. If it works OK and isn't a security risk, it's fine.
Go through each menu--from Microsoft (their sound icon executable), and C-Media Control Panel/Task tray executable--tinker, if necessary, to obtain function and enhanced function....
Jul 19, 2014 | ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3,...
Onboard video card not working. New card not either
please check Ram bcz its ram beep sound may be ram not attached in proper way that why sound come or may be its damaged
May 10, 2010 | ASUS M2NPV-VM Motherboard
Onboard sound card not working (ASUS A7S333). I had a pci sound card and removed it to go back to the onboard sound.
You have to refresh your system by deleting the old sound card driver in the control panel or add/remove programs . Then restart the pc to detect the old onboard sound card driver. Then install the onboard sound card driver using the supported motherboard cd driver.
Feb 12, 2010 | ASUS A7S333 Motherboard
I WANT TO PUT IN A SOUND CARD ON MSI N1996 MOTHERBOARD
Although I'm not familiar with that motherboard the usual way to disable the onboard sound is;
Enter the bios by pressing the Delete key or F2 when the machine starts to boot.
Go to the Integrated Peripherals section and find the On-Board line and change it to disable.
Feb 02, 2010 | Computers & Internet
I downloaded my ECS 661GX-M2 sound driver but still its not working.what should i do?
go into the bios, and make sure that it has been selected to use onboard sound or onboard audio, if that does not work, and if you have the motherboard manual. look and see if it has motherboard jumper settings to use for the onboard sound. ive noticed also with alot of motherboards the built in soundcards dont perform very well but hopefully this will lead you on the right track!!
Jan 15, 2010 | EliteGroup 661GX-M Motherboard
Sound lost on DFI Lanparty 875
do you have another PCI slot you can remove audio card and try another slot.
If your audio still does'nt work you may need a new audio card
Jan 27, 2009 | DFI LanParty PRO875 Motherboard
No sound from p5k3 motherboard
have you connected to the motherboard with correct plug(generally green in for audio out)try with another of speaker if the problem persists than you onboard sound card is having problem
May 15, 2008 | ASUS Computers & Internet
Onboard sound doesn't work
click search, then type dxdiag, click the sound tab and a diagnostic programme will check your sound driver and report any faults
Sep 26, 2007 | Asrock P4VM890 Motherboard
MSI KM4M-L Motherboard Logo
131 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
