Question about Car Audio & Video
Adding an Auxiliary Adaptor to a Matsushita Car Radio Receiver
Above Radio is fitted to my Mazda Premacy 1999/2000 model year MPV. I have attempted to fit an Auxiliary Input Adaptor made by Connects2 to enable use of CD and MD players by direct connection. The adaptor plugs into the 16 pin CD Autochanger socket on the back of the radio and is custom made for this radio model. All I get is 'NO CD' indication. The supplier of the adaptor is baffled, any suggestions?
  • kkandersen53 Jan 20, 2009
    I`ve got the same problem wiht my mazda6 from 2006. I can`t get eny sound out of it.
Need wiring diagram for a MR 587268
Posted on Sep 16, 2011
How to remove the stereo on a 1996 mazda mpv
Mazda MPV Dash Trim Removal, Stereo Removal - Auto ...
? 3:38
https://www.youtube.com/watch?v=REoTeVM2S-o
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
[PDF]MAZDA 1996-UP MPV - Scosche
www.scosche.com/media/guides/ma381.pdf
164. 1996-UP MAZDA MPV. MINIVAN. RADIO REMOVAL USING SCOSCHE DT-1 TOOLS . FRONT DOOR PANEL. FRONT AND REAR DOOR 61/2" 3-HOLE.
DIY Mazda Car Radio and Speaker Removal, How to Remove
www.carstereoremoval.com/htm/stereoremovalMazda.htm
'96-99* Car Stereo Removal ยท Ford Stereo Removal Tools Stereo Removal Tools. How To Install and Remove Mazda MPV Van Car Radio and Speaker, '89-95*
Jan 31, 2016 | Mazda Cars & Trucks
ATF. Oil to use. In. Mazda premarcy which ATF oil can l use?
MAZDA ORIGINAL OIL ATF M-V - Mazda - Gear Oil - Finol Oils
www.finol.ie > Products > Automotive > Gear Oil
Following models can use Mazda Original Oil ATF M-V. Mazda 3, Premacy, Mazda323, Demio, Mazda 121, Mazda 626, Mazda 6, MPV. Suitable for power ...
Nov 19, 2015 | Mazda Cars & Trucks
How to change front brake pads on a 1999 mazda premacy
I always assume when someone asks about
brakes, they have no experience
Could be wrong
Not much difference from one vehicle to another
I would suggest you go to YOU TUBE & may very
well see you exact car & what you need.
You never change pads & nothing else
New pads only go on with machined or new rotors
There is hours of rust removal,solvent cleaning,
a couple different brake lubes required here & there,
fluid flushing every 2 years & during any service.
On the back, you have to learn how to turn in the
parking adjusters on the caliper,just to fit the pads
Sep 12, 2012 | 1999 Mazda MPV
Mazda premacy 02 model, abs and tcs lights dont go out after starting engine.
This is usually a wheel sensor that has gone bad. These are located in the wheel bearings and this is what has to be replaced. But first check the plig and wires, they some times break ot the plug can be corroded.
Jul 04, 2011 | 2002 Mazda MPV
My 2001 Mazda MPV has engine light on when started and blinking while the car is above 40mph. The code is P0303, I changed the spark plugs and new wires. What can go wrong?
recommend you run a compression test. possibly a burned valve or blown head gasket.
Please see my tip at http://www.fixya.com/cars/r6715318-causes_gasoline_engine_misfires . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Dec 14, 2010 | 2001 Mazda MPV
Mazda mpv 2002 coolant leaking somewhere. Filled
it also happen to me on a mazda mpv 2000 for years i was adding anitifreeze i found out that the water pump was leaking just do it yourself easy change just pay $60 dollars for it. underneath the car theres a plastic shield the antifreeze will drip and stay there thats why you didn't noticed the leak.
Mar 02, 2010 | 2004 Mazda MPV
Wiring colours for the sound system MAZDA PREMACY 200
well if you have not cut the wires you can go to wal-mart or autozone ask for a after market wire harnis just tell them the make and model . but if you have cut them then get a light tester
Apr 04, 2009 | 2000 Mazda MPV
Workshop manual for mazda premacy 2002 gasolin
you can find a manual at Napa or Oreillys auto parts store for around 20 dollars hope this helps please rate this solution thanks
Aug 29, 2008 | 2002 Mazda Protege
Car Audio & Video Logo
1,072 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
