Question about Mitsubishi WS-55819 55" Rear Projection Television
It won't power up
I hit the power button the little green light comes on and two seconds later it goes off and the tv never completely powers up. there is a noise in the back of the tv where the power is split into three wires (not sure if this is normal or not).
  • 4 more comments
  • s_botsford Jul 16, 2008
    I bought a used HV splitter and got it all hooked up but i got the same result. when i hit the power button there is a click noise and the power light turns on but in a few seconds there is a second click and the green power light goes off
    yeah still the same noise. is the flyback connected to the "in" plug of the HV splitter? if not, where is it and what does it look like?
    is there a way to test the flyback? i used an electrical tester on both wires coming from the flyback (a white wire and the large red wire) but it showed nothing was going throught either of them? do you think it would still be the flyback?
  • cem0201 Aug 05, 2008
    I have a Mitsubishi WS 55819. When I power it up the green power light comes on for a few seconds. The TV will then power off on its own. It will not power up long enough for the screen to come on.
  • lacehandyman Sep 28, 2008
    I have the same problem it wont power up or say anything. The green light comes on for two seconds the goes off.
  • Anonymous Nov 10, 2008
    the ws-5519 powers on and immediately turns off........What could be the problem?
I have a mitsubishi and the gree power light stays on but no image on the screen
Posted on Sep 21, 2008
  • Mitsubishi Master
  • 8,617 Answers
You need the HV splitter. You can leave a email at the following link state your model number and let them know you need a HV splitter. They will respond quickly to your inquirery and they will provide free tech support to explain how to change the part.
http://servicemanuals.vstore.ca/
Posted on Jul 01, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jul 16, 2008
    It could be the used splitter was bad also, or it could be the flyback which feeds the splitter is defective, does it still make the same noise as it did with the different splitter?
  • Sonny Berry
    Yes the flyback has the other large red wire going into the splitter.
  • Sonny Berry
    Yes. the flyback especially the red wire has a tremendous amount of voltages that run from it if its working. Its a fairly common component that fails. Unfortunately Mitsubishi doesnt make that replacement part anmore its part number 334P278A1
    You can get it still at the link I posted above. There is no way to test a flyback without having a flyback ringer and they are quite exspensive to purchase.
Tv will not stay on
Tv won't stay on - Fixya
www.fixya.com/support/t101679-tv_stay
Tv won't stay on My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds - RCA F27450 27" TV question. ... My TV will notcome on, when I hit the power button the green light flashes but the ..... Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
Why won't my TV stay on? ' Yahoo Answers
Nov 14, 2015 | Symphonic ST420FF 20" TV
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
The green light comes on then turns to yellow.
if you look at the capacitors on the boards you will find several of them that are domed or blown, these are the most likely cause of the problem. you can find replacements for any capacitor online at electronics supply stores, like radio shack but don't try them they don't supply enough different types. you can also find examples of blown capacitors by doing a search for "blown capacitor image" on any web search. unsoldering these bad caps and replacing them with identical values like 220uf (microfarradys) and say 25 v(volts). these caps have a + side and a - side the caps are marked and so is the board. hope this helps.
Mar 20, 2009 | Proview PL926WBi 19" LCD Monitor
Hitachi model 55ux58b
how many times does the light blink?
Dec 10, 2007 | Hitachi 55UX58B 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
