Question about Intel (ATX350P4) 350-Watt Power Supply
POWER SUPPLY IF I WANT TO USE IT WITH A MOTHERBOARD WHICH IS HAVING BOTH FACILITIES OF AT AND ATX, AND PREVEOUSLY USING AT TYPE POWER SUPPLY THEN HOW TO MANAGE ALTERNATIVE FOR POWER BUTTUN?
    Sergeant:
  • 287 Answers
ATX PSU are enabled by a signal on the green wire pin 16.
Shorting of pin 16 to ground (0VDC) will enable the PSU
Refer HERE
Also refer HERE for the 20 PIN ATX
Posted on Jul 06, 2008
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00026876
Motherboard: ASUS P4SD Motherboard Specifications
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00022505&lc=en&cc=us&dlc=en#c00022505_doc
Board Form Factor: uATX
uATX stands for Micro-ATX,
http://en.wikipedia.org/wiki/MicroATX
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/Computer_form_factor#Tabular_information
HOWEVER, the Power Supply is an ATX form factor,
http://www.911forpcs.com/hp-media-center-power-supply.html
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
Having problems with Bestec ATX-300-12z power supply.
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... This is a common power supply that can be purchased just about any computer retailer - BestBuy, MicroCenter, Amazon.
Very cheaply priced, very functional. Even the generic brands.
Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection.
Nov 14, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Can i buy a pwer button for motherboard msi 1076820474446
No search hits come up on MSI 1076820474446.
All you need is an ATX Power On switch, if the Power Supply is an ATX form factor,
http://www.directron.com/atxswitch.html
If the Power On switch does not connect to the motherboard, then it isn't an ATX power supply you are using.
The Power Supply is an AT style.
Has a built-in power switch.
Or I can also show you this,
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
Two main power cables plug into the motherboard. Power Supply has it's own power switch built-in.
A steel rod from the Power On button pushes against the switch.
1) http://en.wikipedia.org/wiki/Computer_power_supply
2) http://en.wikipedia.org/wiki/Switched-mode_power_supply
3) http://www.howstuffworks.com/power-supply.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 30, 2012 | Computers & Internet
My motherboard takes this: 1 x 8-pin ATX 12V power connector My PSU (power supply) only has the 4-pin 12V power connector. Can someone please point me to a product that will convert the 4-pin to an...
Hi Andrew.
Just had a look arouund on Amazon, and if you do a search for
EPS 8-Pin Power to ATX 4-Pin Cable
There are a couple that turn up.
Hope this helps.
Apr 16, 2011 | Computers & Internet
This is my first build and all the connections are a bit confussing need picts of how to install cables to hardware
The following picture will definitely help you to install new power supply.
The 4 pin CPU power connector is using in most of the desktop motherboard. If your motherboard is gaming type or workstation board you need to connect 8pin CPU power connector. Molex connectors are using to power up DVD Drives and HDDs. In New model power supply instead of molex connector SATA Power connectors are coming.
Feb 12, 2011 | Thermaltake Toughpower XT TPX675M 675W ATX...
NEED A NEW UNIT OF POWER SUPPLY ATX-400W REV T1
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Jan 25, 2011 | HP ATX-400W, ATX-400W Rev. T1, HP P/N:...
Bestec power supply model ATX-300-12Z Rev BD green indicating light flashes on off when plugged in.
Jan 06, 2011 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Power supply wont come on
I've check and that board uses an ATX power supply. that is your problem. slap in an ATX and you'll be good to go. Please be so kind as to rate this answer thanks and good luck.
Jan 28, 2009 | ASUS A8N-SLI Premium Motherboard
Problems on PCCHIPS M701G Motherboard
connect your three pin socket in your power plug
Jan 12, 2009 | PC Chips M701G V1.1 Motherboard
Intel (ATX350P4) 350-Watt Power Supply Logo
108 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
