Question about Hitachi 50UX26B/27K 50" Rear Projection Television
Picture problem blue and yellow fading and distorted....Thanks Pete
  • 927 Answers
Good Day,
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, www.bdent.com and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Good Luck, big IRISH.
Posted on Aug 16, 2008
  • Hitachi Master
  • 8,617 Answers
Can you post a picture of your picture so I can see the type of distortion youre having? It sounds like a convergence Issue, but a picture would help me acurately diagnose the problem. Please respond to this same post.
Posted on Jul 01, 2008
Picture is not very clear and the color is faded and can not adjust it
This mite sound crazy but it is time to change the oil in your TV. Yes your TV has three seperate picture tubes on the inside of it. A red tube, blue tube, and green tube. Each one of thses tubes has a clear oil that the light shines through. Over time this oil gets cloudy and distorts the light thus dimming and fadeing your picture please have a tech change the oil in your tubes.
Nov 08, 2010 | Akai PT4250A 42" HDTV
How to fix yellow hue center bottom of picture.what causes this
Most often color distortion is due to the bulb wearing out. Projector bulbs often fade or distort colors before they actually burn out. The other thing you can try is to reset the projector to it's factory settings, which sometimes fixes color issues. It's usually an option in the "settings" area of the menu.
Jan 18, 2010 | Sony VPL PX40 Multimedia Projector
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
Blue screen, no picture for my Magnavox flat screen 42MF7000/17
The problem you describe is being produce the the micro processer, processer is only replaced at fact, but there is some good news.
1- the micro processed sits on the main unit, option replace main unit about 250-350.
2- research companies that might referbish the board.
http://www.ptscorp.com/ better to call them
Mar 18, 2009 | Televison & Video
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Convergence out power supply faulty for 46gw945 picture is distorted
You can get parts for your model by going to the following link and leaving them an email stating the model of your set and indicate which board you are needing. Heres the link
http://servicemanuals.vstore.ca/
May 05, 2008 | GE 46GW945 46" Rear Projection Television
Picture and color distortion
I am having the same problem hopefully some one answers us.
It's a Blue Convergence issue but how to fix it I am still waiting.
Apr 13, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Open Questions:
Televison & Video Logo
61 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
