Question about Grilling
Low gas flame
Char-Broil Commercial outdoor Grill-
There was a greese fire but the grill flame worked for the first two or three
times but the flame is now very low. How do I correct it?
Also read the manual, You must open the LP tank valve very slow, the new tanks have funny safety design, I had low flame on the 2nd use w/full tank and was puzzled because it was high flame on the night before.
Rizzo
Posted on Jul 24, 2008
  • Thomas
    Thomas Nov 08, 2013
    Russo is a rocket scientist. I have one of these Outdoor Mtn Smokers I bought at Gander Mtn. back in 2005. Have been unable to find out why I have been unable to get any heat out of it. Tried the open valve slowly trick and I am smoking happy. This darn thing almost went down to the roadside on Tuesday with the dumpster.
  • 550 Answers
There is probably carbon build up (grease residue) in the orifice of the nozzles, reduces gas flow, they can be unscrewed and replaced, or cleaned with salt & baking soda, see the manufactures web site for your grill for instructions on removing shields to clean the nozzles and orifices
Posted on Jul 01, 2008
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Regulator Repeatedly Reduces The Gas Flow
The new regulators will automatically shut down or reduce flow if the it senses that the flow is too high (as in a line leak or break). It can also be folled if you open the valve too quickly. There is a special plastic plug that can reset a tripped valve in the new tanks. (Mosquito Magnet supplies one with their product).
The other thing is that there is a recall going on at Char Broil of defective thermometers that are reading too low.
Sep 28, 2009 | Char-Broil Commercial Stainless Steel...
Char Broil grill w/full tank and cleaned air jets, no heat
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 17, 2009 | Uniflame FG2204C Grill
SEVERAL DAYS AGO,THE GRILL GREASE CAUGHT FIRE,TEMP WAS 600,TURNED OFF IMM.SINCE THEN GRILL LIGHTS,FLAME IS VERY LOW OTHER BURNERS LIGHT BUT FLAMEIS LOW. HAVE CHECKED GAS SUPPLY.EVEN PUT ON A NEW TANK.SAME...
The regulator is damaged. This is the little round between the hose connected to your knob adjustment and the Gas tank. This one is not expensive. it costs less than 30 bucks. Good Luck.
Jul 06, 2009 | Grilling
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
Help! New Grill not flaming properly!
good day,
hope this link below will solve your problem.
grilling
Aug 21, 2007 | Char-Broil Commercial Stainless Steel...
Grilling Logo
901 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
