Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light flashes nine times and tv will not turn on
The standby light flashes nine times and now the tv will not come on
  • 1 more comment
  • Michelle Deroy
    Michelle Deroy Jul 05, 2008
    I have a wega 32 in. sony tv. that the standby light keeps flashing and tv won't turn on. Television is only 2 or 3 years old.what a rip off.
  • dutchtowneag Nov 02, 2008
    My tv does the same thing, I wonder if it is a warranty problem . I bought it 2005 Oct.
  • hatebreedins Nov 02, 2008
    I have the same problem with mine except it blinks 6 times,,it did this one other time,,but i turned it off then back on and it was fine for two days,,now it wont come on at all..i bought a 4 year warranty that expired 2 months ago..so best buy said they would have to charge me $160.00 just to diagnose it..
I had the same problem with Sony KV-32fs120 with 9 blinks. Replaced D645 and D647 on main board with 1.5A1KV diodes from Radio Shack which did the trick.
Posted on Oct 29, 2008
Why won't my tv turn on. The red light blinks nine times one at a time after nine times it stops & tv still won't turn on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 26, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LG LCD 37" GREEN STANDBY/POWER LIGHT FLASHES GREEN NINE TIMES
http://www.tvrepairkits.com/?gclid=CP-_rIXGgbICFUXHtAodv3QAUA Take a look Kolbrun
Aug 24, 2012 | LG Televison & Video
TV won't turn on, standby light just blinks 9 times
hello, Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
regards
shaun
Oct 19, 2010 | Sony KP-46WT520 46" Rear Projection...
TV will not come on. TV standby light blinks nine times continuously. TV is Sony KP-51WS520
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Mike
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
You need to call a Sony service center for this problem. It will cost you less in the long run.
Sony High Definition Projection TV Standby light flashing nine times, tv will not come on.
you could have a bad lamp i have seen new ones do the same thing if not you may have a bad power supply
Jan 29, 2009 | Sony KDS-60A2000 60" HDTV
WON'T TURN ON
nine blinks means that there is a short inside the set you will have to find a tech to troubleshoot the set most probably is the G pcb
Aug 23, 2008 | Sony KP-46WT520 46" Rear Projection...
Standby flashes 9 times
the 9 flashes means your Diode D6116 or D6301 is open on G board and needs to be replaced ...and your chassis is Ax-1x
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
277 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
