Our model 42h83 toshiba projection tv is having color convergence problems (specifically the green). We tryed adjusting the convergence but that doesn't work. We don't want to spend $400 dollars that I am told it costs if a repair person fixes it. Can you please give us the part number that is needed to fix a convergence problem. We have'nt had this TV for long and are disappointed in this breakdown of the set so early. Any other suggestions you have would be appreciated. Thanks Joan and Larry Mackiewicz
  • 8,617 Answers
You need to replace both convergence ICs they are both STK392-110 ICs. You can get replacements at the following link and they provide free instalation instructions with pictures on how to remove and replace the convergence ICs.Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 01, 2008
Convergence setup for toshiba 42in projection
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 06, 2010 | Toshiba 42H83 42" Rear Projection...
Color convergance will not manually adjust, what could be wrong with my set?
Convergence it dead,require change two convergence ICS and all it resitors.Know how to solders.Tries Tv repair World.com,Tvrepairkitscom for the convergence to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 03, 2010 | Toshiba 42H83 42" Rear Projection...
Since this morning my Toshiba 42H83 TV's picture is blurry and has red and green shadows. We have checked all connections and unplugged all devices.
Go into the customer menu for the TV. Select convergence and if you find the colors are skewed or will not align you have a convergence problem.
I am going to post a few photos here of what this looks like--not all will look the same but you will know if it is your problem.
If it is your problem I can tell you what is needed to fix it--for many it can be a do it yourself repair.
If this information helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Toshiba 42H83 42" Rear Projection...
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
I have double vision on my projection tv (toshiba 42H83).
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Toshiba 42H83 42" Rear Projection...
42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
Aug 10, 2008 | Toshiba 42H83 42" Rear Projection...
Convergence problem with Toshiba TV 42H83
I am still working on it! Need a technician in Alacante Spain!
Jul 25, 2008 | Televison & Video
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba model tz50v61 convergence
need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Mar 16, 2008 | Toshiba 42H83 42" Rear Projection...
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Aug 04, 2007 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
