Question about Lexmark C510 Laser Printer
My printer won't print
When i go to print a message comes up with 900 service RIP software and it won't print anything. Can you please help me?
  • 1 more comment
  • aflanagan Sep 03, 2008
    I got the same thing, please help thanks.
  • bbell1 Oct 06, 2008
    Completely the same problem.  Reboot and the printer works, but let it lapse into an idle state and the 900 Service Software RIP code returns.
  • lift1727 Dec 25, 2008
    i have the same problem pleace help
I have the same problem can some one help me
Posted on Dec 25, 2008
Throw out your POS lexmark and buy something else
Posted on Sep 06, 2008
RIP SOFTWARE 900 SERVICE ERROR
The 900 error usually indicates a software or communications problem. Please try to do the following.
  • Disconnect every cable, except for the power cord and turn off the printer.
  • Turn on the printer and see if the error returns
  • If the error does not return, try to print a test page from the Test Menu
  • If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  • If the
Jul 25, 2011 | Lexmark Optra T620 Laser Printer
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
what is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
Aug 14, 2008 | Lexmark Office Equipment & Supplies
My Dell M5200 printer says 900 Service and RIP Software. I have restarted it several times and checked the menu - all looks o.k., but it won't print. It sounds like it is going to and then the above...
900 RIP error message is a generic error.
In order to understand when it's coming from you have to give more information.
Does it happen when printer is printing a job from a PC, or when it just stands alone idle?
In first case it's probably a job that is generated by the driver which cannot be properly "digested" by the printer. In this case, press select and return on the OP as soon as you get the secondary code message and write it down. Then call Dell support and tell them about it.
If the printer is getting 900 RIP error when being idle, I'd recommend disconencting it from the network for a couple of days to see if the error appears. If it doesn't, then it's something from the network which is causing the problem. Perform the same procedure of collecting the secondary code and contact Dell.
If it still gives 900 RIP error when disconnecting, then it's one of the hardware part which is causing the problem. It might be an option such as a drawer, or a memory unit, or just a main board. try disconnecting one by one the options and see if the problem goes away. Whenever it comes back, collect the secondary codes.
hope it will help, dont forget to thumbs-up
Nov 15, 2010 | Dell M5200n Laser Printer
What does 900 Service RIP Software error message mean and how do i reslove it
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Aug 02, 2010 | Lexmark Optra T610 Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Lexmark C510 not printing - message 900 service RIP software
Hi, This error could be due to several things, the most common one is that whatever is being sent from the computer is not being recognized by the printer causing the 900 Rip Soft Error. You can try to reset the printer and try sending the print job again. If the error persisted. Then the problem could be a hardware problem with the System Board.
Jan 13, 2010 | Lexmark C510 Laser Printer
I am getting a message that says 900 Service RIP software - what does that mean? I cannot print.... help??
This means there is a problem with the engine board. You can try to reset to factury defolds. Turn off the printer, push the buttons 2,3 and 5 and than turn on the printer. When message "reset to defolds" apears release the buttons. If this does not work than you have to exchange the engineboard.
Good luck, Gerrit Jan
Aug 10, 2009 | Lexmark Optra T610 Laser Printer
Message saying 900 Service RIP Software.
This typically indicates a controller board failure. I would need to know the exact printer
model to tell you what part you would need order.
Example: T632N model uses part number
56P3083 -- CARD SYSTEM NETWORK T632N
You can look up various printer models and parts lists here at fastprinters.com
Jul 22, 2009 | Lexmark T522 Laser Printer
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
May 04, 2009 | Dell Office Equipment & Supplies
Lexmark C510 Laser Printer Logo
661 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
