Question about Philips GOGEAR SA6045 MP3 Player
My philips go gear keeps saying please connect player to the PC but when i hook it up to the computer it does nothing may i please have some help
  • krittika23 Jul 16, 2008
    i've downloaded the devices of philips yet when i connect my ipod,the ipod gets charged but it doesnt get conneted....to the system.... so in this way m not able to put songs in the ipod... please help out
Hold volume + button plug the device to the computer (while holding the volume + button) a window should pop up about 5-30 sec later.
Posted on Jul 15, 2008
How do I delete music off of a coby mp829 player
I don't have this particular device. Although some players will let you delete files from the device alone, some won't. But an mp3 player should show up on your desktop computer as an external memory storage device when connected via USB. You can open it and delete music files by dragging to trash, or by right-clicking and selecting Delete. (Windows, but probably similar on Mac).
Jan 09, 2017 | Coby Audio Players & Recorders
I have a Toshiba Satellite A665-S6088. The last time I used it was last night and everything worked fine. It works with Windows 8.1, it has for a few months now, never had any problems until now. No...
Unplug the unit from ac power. Remove the battery. Wait a minute. Press and hold down the power button for 30 seconds. (Yes, I know, nothing will happen visible). Replace battery. Plug unit back in. Now try the power button and see if the unit resets. Sometimes this helps when all else fails especially with a computer which has "hung up" like yours. Let me know if this worked!
Aug 26, 2014 | Audio Players & Recorders
How do I connect an sbt-105 bluetooth headset to my computer(or is it even possible)?
Does your PC have blue tooth enabled? It may need a blue tooth dongle in order to see the headset
Aug 21, 2014 | Samsung Att Captivate Glide Over The Head...
Why does blue light keep flashing when my HMDX boom box is turned on
clip_image002.jpg if it is a slow flashing that means it is connected
if it is a fast flashing that means it is pairing
Jun 01, 2014 | Audio Players & Recorders
I cant get in ipod
http://support.apple.com/kb/ht1212
Mar 24, 2014 | Audio Players & Recorders
How to reset my combination lock number on ipod A1236
Hi William
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Apr 03, 2013 | Audio Players & Recorders
HMDX Jam wireless speaker cannot be paired with my computer
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
Feb 02, 2013 | Audio Players & Recorders
I have a 1970's Panasonic Flip Clock Radio. (Model RC6530) The radio works just fine, but the flp clock stopped flipping. There is power going to the unit. I can also hear a low hum from the flip...
It looks like your problem might be an easy fix, at least. If the gear train between the motor and clock got stripped, you'd be in a bit more trouble. If the motor just isn't spinning, remove it from the side of the clock housing. There are 2 screws (or nuts) holding it in place. When you get it off, the cover for the motor will also be off. Apply some 3 in 1 oil, or perhaps just a tiny bit of penetrating oil, and give it a spin. From what I've read, it should do just fine. A lot of people use wd40, but I understand that can gum up over time.
This is a "at your own risk" type of repair, but as long as you unplug it before dismantling the radio, I think you'll be fine.
Feb 10, 2012 | Audio Players & Recorders
I need philips tuner amplifier AH718 SERVICE MANUAL FOR REMEDIAL MAINTENACE
A service manual would have to be requested directly from Philips.
Sep 01, 2010 | Philips Audio Players & Recorders
My headphones connect with the adapter, the blue light is on on both but nothing comes from the ipod. I have performed the factory reset but it still doesn't work. The headphones had worked fine and then...
I have same issue....just took my transmitter apart - the wires connecting the male jack to the silicon board are frayed, disconnected.....you might check that...it's only 2 small screws holding the outercase together....be careful though
Jul 07, 2009 | Logitech Bluetooth Wireless Headphones
Philips GOGEAR SA6045 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
