Question about Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod - cd reset
I recently had my car battery changed and the CD player hasn't worked since - the display says to reset and then turns the system off. I've tried hitting the reset button but nothing happens. Help!
  • Anonymous Jul 04, 2008
    UNPLUG THE HEAD UNIT HARNESS FROM THE HEAD UNIT. WAIT 30 SECONDS REPLUG AND RESET
    Master:
  • 726 Answers
UNPLUG THE HEAD UNIT HARNESS FROM THE HEAD UNIT. WAIT 30 SECONDS REPLUG AND RESET and hold the reset button down for 5 seconds
Posted on Jul 05, 2008
2 Suggested Answers
godspeed808
  • 125 Answers
SOURCE: Sony Xplod cdx-gt310
it is most likely shorted faceplate, either send it to be repaired heres address:http://www.xplodsony.com/support or buy a new one at wholesale at this address:www.godspeedaudioheaven.com
Posted on Feb 04, 2009
I recently installed a sony explode in my truck everything works fine except for when u put a cd in, no sound and the display shows the cd is playing and all the function buttons work i just have no soud...
It sounds like you are using an amplifier. Make sure you are using the blue/white wire to turn the amplifier on. The blue/white wire is amplifier remote turn on and the blue wire is power antenna remote turn on. The blue wire turns off when leaving tuner mode, turning the amplifier off.
Aug 24, 2011 | Sony Xplod CD Player w/MP3 Playback...
How do i reset my clock on my sony xplod cdx gt24w car cd player
To set the clock:
Press and hold the select button until the setup display appears.
Press the select button repeatedly until "CLOCK-ADJ" appears
Press SEEK + (the hour indication flashes)
Rotate the control dial to set the hour and minute. (To move between hour and minute, press SEEK + or -)
After setting the minute, press the select button and the setup is complete.
To display the clock, press the DSPL/SCRL button.
Mar 15, 2011 | Sony XPlod CD Player w/MP3 Playback...
I recently installed my sony xplod to my jeep and the radio, volume works fine. when i insert a cd, i hear nothing, counter and track displays but no sound...please help
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on.
Feb 17, 2011 | Sony XPlod CD Player w/MP3 Playback...
My cd player not working. asking for cd reset, i do reset not wor
there should be a reset under the face or on it press for ten sec
Apr 20, 2010 | Sony XPLOD CDX-GT200 CD Player
No sound to the subs
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
Jul 27, 2009 | Sony XPlod CD Player w/MP3 Playback...
May 20, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Changing faceplate colors.
only the display changes colors.... your deck is doing what it was designed to do!
Mar 18, 2008 | Sony XPlod CD Player w/MP3 Playback...
Sony xplod cdx s11
press Sel until you get on display "Low" adjust level with volume keys + and -....
jgospodaric
Nov 29, 2007 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Does not accept cd
I guess is your using a CD that was made from a blank one.. Try putting in a CD that you didn't burn.. and see if it works Some CD players does not place burnt CD's Hope i helped cya buddy
Aug 11, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Problem accepting CD
Remove the face plate and see if there's a small "reset" button underneath that can be pressed with a pen tip.
Aug 10, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
1,681 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
