Fan Only Won't Work
Have an intertherm E3EB-015H centeral heater and Honeywell therm. Turning the fan ONLY on doesn't work. There is a grey wire in the heater unit not hooked up and two wires (blue and yellow) from the thermostate in the heater not hooked up. HELP!
    Problem Solver:
I jumped the rc and rh wires in the therostat box and now have fan only when selected.
Posted on Jul 02, 2008
E3eb-015h. What size are the filters?
do you not own a yard stick or tape measure .
Nov 15, 2015 | Intertherm Heating & Cooling
My intertherm e3eb-015h electric furnace will not do a thing even temp.on thermostatdont show up breakers are on still nothing
Check to see if the fuse is blown. If it apprears to be blown, replace it. It is inexpeisive and simple. If you locate the fuse, you will be abel to determin if it is blowin becuase you will be erruption or a burnt mark in the fuse wires.
Sep 21, 2014 | Heating & Cooling
The blower turns off but the unit keeps making a loud humming/buzzing sound intertherm E3EB-015H
It sounds to me like you have a transformer that is going to need replaced before too long.It is normal for a transformer to make a low humminig/buzzing sound that you describe but as they get older sometimes they get quite loud.The good thing is they are not hard to replace nor are they very expensive.
I have seen them just be loose on their mounting screws and you might get by just tracing the sound down and tightening the screws. Thank you and good luck.
Feb 11, 2011 | Intertherm Heating & Cooling
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
Oct 06, 2010 | Heating & Cooling
Trying to connect kenmore heat pump thermostat to honeywell therm
reversing valve orange wire goes to o or b terminal depending if energized in heating or cooling
May 11, 2009 | Honeywell Programmable Thermostat Heater
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
