Question about Dell Inspiron 1501 Notebook
Hard drive error #0041
Almost everytime I close the lid on my lap top or power it on it gives me an error stating that there is no hard drive available to boot. The only way I can use the computer in between the error message is when I hold the power button and remove the battery before turning the lap top back on! PLEASE HELP, COMPUTER IS ONLY 20 DAYS OLD!
    Genius:
  • 2,028 Answers
This sounds to be a hard drive issue. Run a DST or short test diagnostic, this will give you a pass or fail on the hard drive. The other thing that is concerning is having to take out the battery in order to start. This generally occurs when a battery develops a dead short, but usually it's a well used battery. This is a hardware issue and it will not get any better. If you can, take it back and exchange it, RUN don't WALK because most retailers do not like to exchange electronics and the return period is generally short. I am a firm believer in Dell, they make good machines, and you should not have these issues with this machine, even at 2 years old much less 20 days. Be firm with them and demand an exchange, even if you have to take it to management. Also tell them you spoke with a tech (they don't have to know that it was over the internet) and his advice was exchange because the machine shouldn't have these problem at this point. It's still a baby!!!
Posted on Jul 01, 2008
My dishwasher fisher pykel twin dish washer model # DD 605 , SHOWS AN ERROR CODE f7 first then shows error code f9
The top dishdrawer is hard to open or close as the lid seal actuator motors are most likely faulty or lost power. The scraping is the lid seal touching the drawer lid. The F7 and F9 error are a result of this fault with the actuator motors.
At the base of the dishwasher housing under the bottom drawer is the power board. From there the power is supplied to the controller and the motors. These motors move the lid seal into position. First turn the mains power to dishwasher off and then back on. See if this resets the motor position. If not you will have to call the technician to fix the problem. But if you are technical savy you could go to the base of the dishwasher and take the connectors of drawer 1 out from the power board and swap with drawer 2 which is working.
If power board connection is not making any difference, then motors are the likely problem. Needs a lot of expertise to replace and adjust the motors.
Mar 23, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a Toshiba Desktop Ext Hard Drive PH3100U-1EXB ... i unplugged it from my desktop to plug into my laptop like i have done before but this time it wouldnt load so i tried to eject it but it wouldnt...
but does it still work on the desk top.
if yes, then you have lap top issues, ONLY.
easy ,huh?
try all lap top USB ports no ext. hubs allowed.
what is wrong in the LAP top OS, unstated)
are you using the correct external power adaptor for both Desk and lap top usage,
have you tried a diff. usb cable.
Laptops can not power the hdd via the USB at all, and in fact
should be avoided at all times. no matter.
the laptop can be infected.
the laptop might have USB issues, with drivers.
do a USB driver update. (no 0S stated)
does the HDD show up in Disk manager, as DISK2
can you set the drive letter?
can you set the volume label on this disk via DM?
if yes, you then can read and write the drive.
as stated on all pages for USB
disconnect all other USB devices, and now try this HDD.
do a full virus scan, and malware scan
do wInDoZ update.
I think i hit them all.
Oct 01, 2013 | Computers & Internet
Media disconnected error on ibm r52 thinkpad
Change the hard drive, it is clear this is a hardware issue.
Jul 27, 2012 | IBM ThinkPad R52 Notebook
WD essential 1tb I cannot open the software on my laptop. A window pops up saying WD has encountered a problem & must close program, send or don't send option is all. How can I access my Passport? It...
Hi: That portable hard drive is USB 2.0 is the port on the laptop USB 2.0 can you use a memory stick to transfer files from the one lap top to the other lap top then on to the external drive.
Mar 16, 2011 | Western Digital WD My Passport Essential...
AHrd drive Beebing and not reconized by my lap top
try using another usb cable and another usb slot on your computer. the drive is not recieving enough power from ther computer.
Jul 14, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Acer aspire 2920
Disreguard the product recommendation. You posted your question in the hardware recommendation section which is for upgrades and such.
For a lap top you can unplug the batteries and power cord. Then press and hold the power button. This is called a power-drain.
Then I would remove the hard drive and make sure there are no bent pins (if older IDE type). Then I replug the hard drive
and replace the batteries and power plug.
Reboot the laptop and enter bios. See if the hard drive is detected. I
F still nothing, try another hard drive in the lap top
or
try that hard drive in another machine/hard drive enclusure to see if it works.
If the harddrive checks out then maybe the laptop hard drive connection is damaged.
That would be verifed with another hard drive.
Hope this helps.
Jul 10, 2009 | Computers & Internet
Lap top will not boot correctly when not connected to ext hard dr
First u check the laptop Display
if it has display, thn it might be problem ur windows
instead of it.
if computer does not give display thn u check the power adopter of ur laptop.
after all gonig through these steps.even u find all these above steps perfect.
it will mean,
it might be problem of ur hardware.
lets check out it by ur computer vendor.
Thanks
Danish khan
Feb 01, 2009 | Western Digital My Book Essential Edition...
Pc hard drive
Yes, that correct you can just need to take the hard drive from your desktop and get a external hard drive ecnlosure where you need to put the hard drive and connect it to your laptop via USB cable, check this link for the sampole of the hard drive enclosure that you need to buy http://www.tigerdirect.com/applications/Category/category_tlc.asp?CatId=2777&name=Hard-Drive-Enclosure
Hope that helps.........
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
`lacie hard drive
empty your trash. and youu be pleased
Sep 03, 2008 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
112 people viewed this question
Alun Cox
