Question about HP PSC 1210 All-In-One InkJet Printer
Hp 1210 all in one printer - error message
Cannot get rid of this error message. The printer is offline and still displays this error message.
How can i reset to the factory settings?
Dennis.
  • 2 more comments
  • pb0430 Jul 07, 2008
    I cannot get rid of the error message "check printer cartridge". I put in a new cartridge about a week ago, and it printed fine then. I have tried to press "cancel" button and print an alignment, but it will not print anything. I have taken the cartridge out several times and it don't effect it at all. I wanted to make sure the cartridge was in correctly and was the right one too. I put the old cartridge back in and the printer has the same error message and "E" light blinking. I just don't know anything else to do??
    I guess the printer is about 4-5 years old, its a HP psc 1210, bought at "Office Supply" in Sanford, NC.
    Thank you, Mrs. Peggy Buchanan
  • Anonymous Apr 04, 2009
    Please help me!! It has nothing to do with the printer, it happens when the paper runs out of jams.
  • Anonymous Mar 14, 2014
    offline
  • Anonymous Mar 16, 2014
    how do you reset the printer error messages on start up?
  • 181 Answers
Two problems;
1 - This unit cannot be set back to factory settings as it does not have the keypad to enable this functionality.
2.
Most of the time when the error pops up it is due to problems with either the printer reading the cartridge is in from the contacts or the cartridge contacts are damaged.
I should also point out that refilled and remanufactured cartridges are the number one reason for the error but assuming that you are using hp cartridges fresh out of the pack take a look at this link and follow the steps. I would type them out but it even has pictures for easy reference!!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042818&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
If you are not using hp cartridges then replace with genuine cartridges and it will most likely resolve the issue - the printer is able to tell the difference between a new and refilled/remanufactured and often times will reject the cartridge because of this.
Posted on Aug 07, 2008
This is how to reset your HP PSC 1210:
* Set your computer system date to a date before the expiry of the ink cartridges.
* Start the following program:
C:\Programs\Hewlett-Packard\Digital Imaging\bin\hposvc08.exe
* Use the password "Homer"
* Choose the reset directory
* Hit the total reset button
* Follow the instructions ...
Posted on Aug 29, 2008
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have a hp psc 1200 . i have not insert the printer cartridge. will the scanner work ?
Inkjet Printer will not operate with out the ink cartridges inserted. The Error message on display will not allow the printer to work.
Regards
Riztech
Jun 16, 2010 | HP PSC 1210 All-In-One InkJet Printer
My HP 1210 All-in-One printer can print but not scan. Get error message. What do I need to do?
Completely uniostall, reboot the computer and re-intall the drivers. Remeber not connect the printer until it is demanded.
thanks.
Dec 29, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP 1315xi psc all in one error offline
Go to Control Panel- Printers
Right-click on your printer and click on Use Printer Online.
Hope this helps!
Aug 03, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer status- error offline
first go to services.msc refresh the spooler service. then insert the printer disc in to the computer . do a level 2 uninstallation .
restart the computer then again again reinstall the software issue will resolved
Printer ink cartridge not recognized by printer hp psc 1210
some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Feb 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP Printer will no longer scan
Hi Keithcarrol
Please do the following
1. Go to Control Pannel then sellect Add/Remove Programs and uninstall all HP Software.
2. Disconnect all Prinetrs
3. Go to Control Pannel then sellect Printers and Faxes make sure there is no Printers in there if there is delete them
4. Install Psc 2210 software and follow instructions on when to connect printer.
Dec 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
Feb 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
3,704 people viewed this question
Seeker5211
Seeker5211
