Question about Maytag Dryers
My Maytag dryer is rumbling when it starts up. But, it is drying OK.
Check for loose 'tumblers' inside the drum. I have heard of some cases of these coming loose and causing knocking in the drum.
Posted on Jul 01, 2008
Comercial maytag dryer will not shut off. tried replacing timer. heats up but will not shut offf
When a dryer heats but the timer does not advance especially on the auto. dry setting (not timed dry) the problem is usually always a airflow problem. What needs to be checked is for lint build up in the blower housing, a blocked or restricted. Also on Maytag dryers a problem sometimes is that the blower wheel drive hub where it connects to the motor is stripped so the blower wheel cant move air,typically if that is the case a rumbling will be heard when dryer starts and once again when the dryer stops a rumblimng noise will be heard.
GENE
Sep 23, 2011 | Maytag Dryers
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Dryer initial had rumbling sound when started and then quieted down to normal. It now makes a rumbling sound through the complete dry time
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 31, 2010 | Maytag MDE2600 Electric Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Maytag LDE8414RCM, dryer knocks and rumbles while running. Still heats and dries clothes for the moment, but the knocking and rumbling is getting worse. Thanks
That rumbling noise may be due to the fan impeller being loose on its shaft, or because of a worn rear support roller. If the machine is still drying, it may be taking longer than usual but you haven't noticed. This is a good sign it's the fan. There are a number of sites with good detailed procedures for getting at and replacing parts, as well as selling the parts you need (of course they would!). One of them is here:
http://www.applianceaid.com/maytag-dryers.html
If this solution gets you on the way to quiet drying, please take a moment to rate it. Thanks for asking here!
Feb 21, 2009 | Maytag Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Rumbling noise
Time to call GHOST BUSTERS!
Here is a good service!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 22, 2008 | Maytag Performa PAV2200
Dryers Logo
69 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
