Question about Canon Office Equipment & Supplies
Canon imagerunner 20201 copier - need to change settings to print sheets lengthwise, not sideways. Someone changed settings.
checkitright
  • 1362 Answers
SOURCE: Canon imageRunner 1023iF won't print--offline
change the cable, there is a bad connection once you put a new one it should say ready
Posted on Oct 15, 2007
iservice
  • 318 Answers
SOURCE: I have a Canon Imagerunner
There is something wrong with the finnisher,check if the stapler unit is not stucked and in the home possition.Check if the finnisher trays is not stucked.
If it is an external finnisher you can unplug it and move it away from the machine.and you will be able to carry on copping wile wating for tech support.
Posted on Dec 19, 2008
iservice
  • 318 Answers
SOURCE: Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Posted on Feb 02, 2009
gunninfo
  • 59 Answers
SOURCE: Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Posted on Apr 20, 2009
komguy
  • 2306 Answers
SOURCE: Default Settings for Canon Imagerunner 3025 Scanning
You will find those settings in your scanning software on your computer, since all of them are different, there is no one right answer. Some you have to choose each time you start a new job or document.
Posted on Jul 22, 2009
WANT TO CHANGE PRINTING FROM LANDSCAPE TO PROTRATE
that is a print driver issue and needs to be changed in the default setting within the print drivers. talk to your IT people if it is a company and ask them for help changing that setting or you can change it yourself if you know how to reset the defaults in the printer driver.
May 11, 2010 | Canon imageRUNNER C3200 Copier
I need to set up my canon color imagerunner for wireless access
What model number is it? I don't think it has wireless printing! You'll need a wireless hub.
Nov 03, 2009 | Canon Office Equipment & Supplies
Canon Imagerunner C3200 Service menu
try *28* but remember to press 28 a the same time. * is that button next to the screen with little ring(head) and star in it.
Jul 22, 2009 | Canon imageRUNNER C3200 Copier
Scanner won't pick up colored inks from paper, multiple sheet jam
This printer only prints black and white. Canon do not supply Multi-color toner catridges for Canon Imagerunner 1023N
Jan 10, 2018 | Canon imageRUNNER 1023N Black and White...
Printing wrong fax number on paper headings
HI
Cant find a manual for that model but this is close enough for changing the details i think.
Download it from here
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IMAGERUNNER%202025I-_E
Feb 16, 2009 | Canon imageRUNNER 3035 Black and White...
STACK BYPASS option causes LOAD PAPER message & no print
1-did you change to bypass instead of trays in the menu?
2-the sensor (black lever in the bypass that triggers the sensor) is missing or bad
Oct 09, 2008 | Canon imageRUNNER 400S Copier
Won't Print
Did anyone change some thing in the computer?? Or added new software?? Also, did someone change the user setting on the copier, Maybe to just a copier or just a fax??? Do some huntting and get back to us
Jun 25, 2008 | Canon ImageRUNNER 1670F Copier
About canon ir 300-400
i required the ppd file for install the canon imagerunner 400 printer for linux systems.
pls mail it for jeevan.rak82@gmail.com
Dec 11, 2007 | Canon imageRUNNER 400 Printer
PRINT ROTATE
Hello. Try setting the casstte sitch located just inside the paper cassette, coloured blue, to the A4R setting. Let me know?
Nov 21, 2007 | Canon imageRUNNER 2000 Copier
522 people viewed this question
old marine
old marine
