Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Lamp error when i turn the tv on i get a lamp error warning press the end button and it still works. does this actually mean i need to replace my lamp? it also says i need to reset my clock. how do i do this? I lost my manual so im flying blind>
  • 2 more comments
  • schimpf2 Jul 03, 2008
    i have the exact same issue. the warning comes up and then i exit the
    warning screen and the tv has worked now for over 2 weeks.
  • Anonymous Aug 31, 2008
    how do i reset the lamp timer on pt-50lc14 50
  • jasper2017 Oct 03, 2008
    I get the same warning. The question I have is do I need to replace the lamp now? Or should I wait until the lamp does not work? Is the warning based on the lamp starting to fail or just based on a counter?
  • spqr163
    spqr163 Mar 13, 2009
    keep a manuel , can get one online, but you need to replace the lamp then reset the counter to do this press the (-) volume on the tv then the pip button on your remote hold them down that will reset the counter
  • 37 Answers
Keep an owner manuel, can download one online, but you need to replace the bulb, then reset the counter. to reset the counter press (-) volume on the tv then while holing that down press the pip button on the remote that will reset the counter
Posted on Mar 13, 2009
  • spqr163
    spqr163 Mar 18, 2009
    bulb might be going, keep an extra one on hand, then if you do replace it make sure you reset the counter....
Mitsubishi WD-52327 TV won't consistently turn on, new lamp
the problem is in the power supply circuit
capacitor may be or so the click mean theres cap are leakink or get dry that why is so long to power on.
hope that give you a idea.
May 05, 2010 | Televison & Video
Tip
Lamp Reset Procedure for Panasonic TVs.
You have replaced your lamp and the set is working fine but the 'replace lamp light' is still on. What do you do?
This is an important procedure because you need to know when it is time to replace the lamp again. If you do not reset the timer you may run the risk of having the lamp explode, because it was not replaced in time. This can be dangerous and could cause a fire.
Manufacturers have lamp timers built in to their TVs so that when it gets close to time to replaced the lamp you are made aware of this and if you heed the warning you may save money by not damaging other components such as the ballast. If you do not heed the warning, you are on your own and deserve whatever happens.
If you have replaced the lamp in your Panasonic DLP TV and are having problems you probably need to reset the lamp counter.
This should solve your problem
1). Turn on the television.
2). Press the down button on the TV display (not the remote)
3). While pressing the volume button, press the "split" or "PIP" button on the remote.
I suggest writing your lamp hours on a piece of masking tape and taping it to the back of the TV for future reference.
This should reset your counter and you will be ready to enjoy your TV for about another 8000 hours.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
hardrocko
on Jan 29, 2011 | Televison & Video
Tip
Lamp Reset Procedure for Samsung Televisions.
You have replaced your lamp and the set is working fine but the 'replace lamp light' is still on or the lamp light is blinking. What do you do?
To reset first make sure the TV is powered off.
1) Point your remote towards your TV.
2) Press MUTE + 1 + 8 + 2 + Power.
3) Your TV should now say "Loading Factory".
4) Browse down to "Option" then press ENTER (or the right cursor button).
Note: The MUTE + 1 + 8 + 2 buttons need to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
5) To exit the service menu press the EXIT button or just turn the TV off. Do not turn on the TV immediately after. Let it off for several minutes.
hardrocko
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Sep 16, 2009 | Panasonic PT-60LC14 60" Rear Projection...
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
How do you reset the warning to replace lamp.i replace the lamp on my pt-50dl54 but the replace lamp still comes on
Turn your television on
Press volume down on the TV
Press the mute button on the remote
Green LED light on power button will flash
-timer now reset (no more warning light)
Nov 15, 2008 | Televison & Video
Resetting lamp replacement warning
Turn the TV on and press recall to clear the warning. Then hold down the volume " - " button on the tv and the PIP (Play) button on the remote for ~ 5 sec
Apr 03, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Zenith Lamp Light on
When the lamp is replaced the lamp timer must be reset. The timer is set for just so many hours and then the warning lamp is illuminated. The only way to reset the lamp that I am aware of is with a zenith programmer remote. Perhaps you can find a local lg/zen service center to allow you to use a programmer and instruct you on resetting the timer.
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
214 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
