Question about Linksys Wireless-G WRT54G Router
Home networking. I have my Speedstrean 4200 connected to my computer by USB cable because when I use the ethernet cable it says I don't have a PCI slot. When I try to connect my Linksys wireless G WRT54G it won't let me because I'm not using the ethernet cable. Any help would be greatly appreciated.
  • smityjay Jul 01, 2008
    Thanks for the help I resolved the issue myself. I uninstalled the software and reinstalled it with new drivers for my modem and router and it's working perfectly now. Thanks for the help!
    Novelist:
  • 126 Answers
Do you have a pci network adapter intalled with the proper drivers ? did you plug in ethernet cable directly into current pci lan card it will be located on lower part of back of computer? this will eliminate the problems with the router just to see if pci lancard is working or not . if the lan card is working unplug cable and plug in router and then try with router plugged in u might need to reset the router in order for it to work with lan card . if ur using and onboard lan eg attached to the motherboard then you must go into computer bios and enable onboard lan and then the ethernet cable should work with no problem good luck i hope this helps you get up and going getback to me if there are future problems.
Posted on Jul 01, 2008
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
Tip
Connecting Two Computers Directly With Cable for a home network
The simplest and easy way to start a home network
The simplest kind and easy to maintain of home network contains exactly two computers. You can use this kind of network to share files, a printer or another peripheral device, and even an Internet connection. To connect two computers for sharing these and other network resources, consider the options described below.
The traditional method to network two computers involves making a dedicated link by plugging one cable into the two systems. Several alternatives exist for networking two computers in this manner: Ethernet crossover cable
Null modem serial cable or parallel peripheral cable
Special-purpose USB cables
Ethernet - Of the above choices, the Ethernet method is preferred as it supports a reliable, high-speed connection with minimal configuration required. Additionally, Ethernet technology offers the most general-purpose solution, allowing networks with more than two computers to be built fairly easily later. If one of your computers possesses an Ethernet adapter but the other has USB, an Ethernet crossover cable can still be used by first plugging a USB-to-Ethernet converter unit into the computer's USB port.
Ethernet crossover cables
Serial and parallel - This type of cabling, called Direct Cable Connection (DCC) when using Microsoft Windows, offers lower performance but offers the same basic functionality as Ethernet cables. You may prefer this option if you have such cables readily available and network speed is not a concern. Serial and parallel cables are never used to network more than two computers.
USB - Ordinary USB cables must not be used to connect two computers directly to each other. Attempting to do so can electrically damage the computers! However, special USB cables designed for direct connection exist that can be used safely. You may prefer this option over others if your computers lack functional Ethernet network adapters.
To make dedicated connections with Ethernet, USB, serial or parallel cables requires
each computer have a functioning network interface with an external jack for the cable, and
the network settings on each computer appropriately configured
One phone line or power cord cannot be used to directly connect two computers to each other for networking.
Connecting Two Computers with Cable through Central Infrastructure
Rather than cable two computers directly, the computers may instead be joined indirectly through a central network fixture. This method requires two network cables, one connecting each computer to the fixture. Several types of fixtures exist for home networking: Ethernet hubs, switches, and routers
USB hubs
Phoneline and powerline wall outlets
USB hubs
Implementing this method often entails additional up-front cost to purchase more cables and network infrastructure. However, it's a general-purpose solution accommodating any reasonable number of devices (e.g, ten or more). You will likely prefer this approach if you intend to expand your network in the future.
Most cabled networks utilize Ethernet technology. Alternatively, USB hubs can be employed, while powerline and phoneline home networks each offer their own unique form of central infrastructure. The traditional Ethernet solutions are generally very reliable and offer high performance.
Connecting Two Computers Wirelessly
In recent years, wireless solutions have enjoyed increasing popularity for home networking. As with cabled solutions, several different wireless technologies exist to support basic two computer networks: Wi-Fi
Bluetooth
infrared
Wi-Fi
Bluetooth
infrared
Wi-Fi connections can reach a greater distance than the wireless alternatives listed above. Many newer computers, especially laptops, now contain built-in Wi-Fi capability, making it the preferred choice in most situations. Wi-Fi can be used either with or without a network fixture. With two computers, Wi-Fi networking minus a fixture (also called ad-hoc mode) is especially simple to set up. How To - Set Up an Ad Hoc WiFi Network
Bluetooth technology supports reasonably high-speed wireless connections between two computers without the need for a network fixture. Bluetooth is more commonly used when networking a computer with a consumer handheld device like a cell phone. Most desktop and older computers do not possess Bluetooth capability. Bluetooth works best if both devices are in the same room in close proximity to each other. Consider Bluetooth if you have interest in networking with hand held devices and your computers lack Wi-Fi capability.
Infrared networking existed on laptops years before either Wi-Fi or Bluetooth technologies became popular. Infrared connections only work between two computers, do not require a fixture, and are reasonably fast. Being very simple to set up and use, consider infrared if your computers support it and you lack the desire to invest effort in Wi-Fi or Bluetooth.
If you find mention of an alternative wireless technology called Home RF, you can safely ignore it. Home RF technology became obsolete several years ago and is not a practical option for home networking.
Try it is the best home network option.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
How do i replace the ethernet port on a sony vaio rx860
Bye an ethernet card and plug it into an open PCI slot on your motherboard (if you have one).
Aug 24, 2011 | Sony VAIO Digital Studio PCV-RX860 PC...
HP 4450 desktop, not have a ethernet port
No you can't.
But you have ywo other options to use broadband connection.
1. Use a USB modem, or
2. Install a network card to be able to use an ethernet cable.
A network card cost around $10.00.
Don't forget to rate this answer if it helps
Dec 27, 2009 | Computers & Internet
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
I have a siemens speedstream 4200 and windowsXP.
Are you connecting the modem using a USB cable or a ethernet cable.
If its the USB cable you would need the disk supplied with it and if its an ethernet cable, no installation is required.
regards
Sandeep
Oct 19, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Hard ware problems
HI Barry
You need something called an ethernet cable. One end of the cable goes in the router and the other end goes in the ethernet poet of the computer.
This is an ethernet cable
512c92e.jpg.
This is the network port (ethernet) of the PC
If you dont have an ethernet port on ur pc u may need to pay an ethernet pci card like this and get it installed on your computer
Hope this helps
Cheers
JigSaw
XoXo
Aug 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Siemens 4200 2 computers
Yes and No! The 4200 gives you the option to connect via USB or Ethernet. You can only use one or the other to connect. You have two options. The first DOES involve another "gadget". The second does not!
Solution #1
I realize you're not looking to use additional equipment, but a network hub, switch or router will give you what you need. You can pick up a very inexpensive router for under $50 or even better a wireless router for a few bucks more.
I recommend a Linksys Wireless Router (Model - WRT54G) as it is very user friendly and comes ready to use. Just connect the port labeled "Ethernet" to the "WAN" port of the Linksys Wireless Router. Then connect both of your computers to any of the four "LAN" ports.
Solution #2
You can connect the first computer directly to the 4200 via USB and connect the second computer directly to the first computers ethernet port using a Network Crossover cable. Without a router of hub between the two computers, a crossover cable is required to allow them to talk to each other.
Once you have them connected to each other, on the first computer open the network connection properties for your internet connection (will be the one setup during the install of the USB modem) and click "Share This Computers Internet Connection".
Now the first option is surely the most reliable and keeps the traffic separate.
Hope this help!
Jul 20, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
