Question about Samsung SYNC SGH-A707 Cellular Phone
My alarm clock keeps going off on my Samsung A707 phone and I can't find where to turn it off, set it, etc.
    President:
  • 2,712 Answers
You can download the user manual from here:
http://www.phonedog.com/cell-phone-research/samsung-sync-sgh-a707_user-manual.aspx
That should tell you how to adjust the alarm settings on your phone :)
Posted on Jul 01, 2008
How do I unfreeze my att samsung eternity without a computer cord
Computer card Unlocking is very Big process,So that You can use the Unlock code....also in computer card Unlocking you need to use Cable,Software,USB port,Boxes etc,so take big time ,it's risk process,cost High also,So that i would suggest the Unlock code the simple method to Unlock Your Samsung SGH-A707 SYNC phone,You need to Unfreeze means specify the Network ,Country it locked now?
You can get the Unfreeze Code at
Simpleunlocking and Unfreeze the Phone from Lock...
Samsung SGH-A707 SYNC Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A707 SYNC mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A707 SYNC mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-A707 SYNC with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A707 SYNC is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 SYNC.
Each Samsung SGH-A707 SYNC mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A707 SYNC mobile phone using the form above.
Jul 18, 2011 | Samsung SYNC SGH-A707 Cellular Phone
Tip
All Codes for SAMSUNG SYNC SGH A707
Normal 0 MicrosoftInternetExplorer4 Following are the list of all codes for Samsung Sync SGH A707 with their functions.Use them at normal dial screen and at your own risk:
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Get IMEI: *#06#
Reset phone to factory settings: *2767*3855#
Disable auto sp: #7465625*2877#
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#4777*8665# Power on attach (GPRS tool?)
*#232337# Bluetooth MAC Adress
*#7465625# = Check the locks (network, subset,etc)
*#1111# S/W Version
*#2222# H/W Version
*#232337# Bluetooth MAC Address
*#7465625# = Check the locks (network, subset, etc)
*#0*# LCD Test
*#0228#
Battery info
*#0289# Melody test
*#0782# Show the real time clock
*#0842# Vibration test
*#5002*8376263# Some info
*#0002*28346# <---test mode (another menu)
*#0523# Test Menu
NOTE:ALL ABOVE INFORMATION IS FOR EDUCATIONAL PERPOSE.USE THEM AT YOUR OWN RISK.
on Dec 08, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Tip
Unlock SAMSUNG SYNC SGH-A707.
If you have forgot your phone lock code and you want to unlock it....then all you have to do is to type this code at your normal dial screen:
#7465625*2877#
(Note:This code will reset your phone to default settings and all your data that is stored on your phones memory will be erased,so store your important data on your memory card before you type this code.
FOR more information follow this link: Samsung Sync SGH A707
on Nov 27, 2009 | Samsung SYNC SGH-A707 Cellular Phone
MY SYNC A707 LOCK UP AND WILL NOT LET ME MAKE PHONE CALL OR ACSESS ANYTHING
Click following link to get your phone unlocked by entering unlock code at normal dial screen....
Nov 02, 2009 | Samsung SYNC SGH-A707 Cellular Phone
How do i reset my samsung a707 sync phone when it is turned off?
You have to reset it manually
call samsung tech support 1 888 987 4357
for the manually reset
it will be unlock for sure
Oct 20, 2009 | Samsung SGH-A707 Cellular Phone
SGH-A707 FILE DISPLAYS AS EMPTY IN MY COMPUTER
Go to samsung website and download there free program called; samsung pc stuido 3. I have vista os and it works just fine.
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SGH-A707&mType=SW&vType=L&disp_nm=Sync(SGH-a707)
May 17, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Cell phone key volume
Go into settings and search somewhere either for Main Menu settings or for Sound Settings. If you cannot find it then, just open every setting and read them. You will find it. Hope I Helped!
Jan 29, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Alarm
try a master reset *2767*3855# this will blank the phone as if you just bought it from the store....hopefully this helps.
Mar 21, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung sync at&t sgh-a707 cell phone
I had the same problem and fixed it by turning off the phone, removing and re-inserting the battery.
Nov 19, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone wont send pictures anymore
Check your phone's network connection option to ensure it is at the right one. Goto settings,connectivity, IMS settings,profile, then chose the providers network option.
Oct 29, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
349 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
