Question about Hoover HW160M Front Load Washer / Dryer
HOOVER HW 160M WASHER/DRYER
Door won't open, it goes through the cycle ok and does what it should do but will not release the door. Any ideas.
Fixed it myself with help from UKWHITEGOODS web sight, excellent sight. No help from your sight whatsoever won't be using you again.
Posted on Jul 02, 2008
My malber wd2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won\'t release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don\'t pull too hard on the white door handle. If you can\'t open it with your little finger (seriously) it\'s not ready to open!
Nov 14, 2013 | Malber WD2000 Front Load Washer / Dryer
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Maytag Neptune door won't lock, or start the was cycle.
check all wiring for tightness and any corrosion from door latch up to the central control unit first,if ok then replace door latch component as this part wears out quickly you will need to remove washer top,then door boot spring to release door boot from door frame to access wiring to door lock component
May 06, 2012 | Maytag MDE5500AYW Electric Dryer
Hi i have a tecknik washer dryer, the machine did not finish a spin cycle left the clothes soaking, the machine door did open eventually but i get no lights on the panel , i have checked the fuse and it is...
If the washer started a spin cycle and some water was released, I would suspect a block drain line.
And the locked door reenforces my belief.
Tecknik does not have a good drain cover over the output line and sometimes something small like a sock will clog the line. If you disconnect both ends of the line you should be able to unclogg it. But be ready to deal with the soap and water released.
Jun 07, 2011 | Tecnik TKL9260 Front Load Washer
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Dec 20, 2010 | Washing Machines
Door on WD420 will not open
There is an electrically controlled lock on the door that prevents opening while the machine is in operation, and sometimes for a short period after a cycle has finished.
Sometimes this lock can get stuck and requires some persuasion to release.
This may sound odd but try it:
Make a fist with your hand and bang the door, near the latch, with the side of your fist. Do this firmly, but obviously not so hard that you will damage the door or, more importantly, your hand. This can often release the latch that should have released automatically.
Apr 07, 2010 | Hotpoint Aquarius WD63 Front Load...
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Hoove HM6316M Dryer not drying
Where was the water leaking from ?
Has it leaked onto the dryer electrical connections ?
You need to check if there is a circuit board behind the fascia panel.
please let me know these answers
good luck
Jan 25, 2009 | Hoover HW6 160M Front Load Washer / Dryer
Faulty on off button
the only way you can open the door is by switching off the washer open the lid feel down the front off the inside of the washer to were your door catch goes to you will find a catch you can release to open the door
Dec 11, 2006 | Candy AQW130 Front Load Washer / Dryer
Hoover HW160M Front Load Washer / Dryer Logo
213 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
