Question about Maytag M6Y12F2A Air Conditioner
EE problem What do you do when you get en EE on your air conditioner and it shut off?
  • mmack121 Jul 07, 2008
    My air conditioner won't turn on. EE shows up. What do you do?
  • gipelon Jul 09, 2008
    My AC was running fine when I went to sleep, but woke up around 4:00 am and the unit was off and the readout showed "EE"
  • 3 Answers
It could be the control board. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Posted on Jul 08, 2008
  • sue368 Sep 06, 2010
    i know this is an old post but i have the same problem on mine it's model no is m6y12f2d-a could this be the same air conditioner if so i would like the part no if you still have it i know it is a lot to ask thank you
  • Amir M
    Amir M Oct 16, 2013
    I have same problem. I dont know what is the model number and appreciate your guidfance
Displaying "EE" Code. Does not run.
the best suggestion is to contact the manufacturer at: (877)337-3639.
Jun 19, 2014 | Haier CPN10XCJ Air Conditioner
What causes a unit will turn on for about 1sec and then shuts down with the letters EEon display
EE is an ERROR code typically it is a disconnect from the control and the unit, this is inclusive I believe so the thermistor or sensor is bad or off at the board.
Jun 06, 2014 | Fedders A6Q10F2B Q Chassis Room Air...
Flashing EE:EE on airconditioner wall control
your system might need reseting look for a reset switch on your thermostat or your inside unit usually means dirty filter
Jan 04, 2013 | Heating & Cooling
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
Shows ee and will not come on
EE is an error code. I cant help you with this one , but it means something has failed. Try the Fedders site or a Fedders Agent who may be able to state what the EE code means and then see if you can purchase or obtain a Tech to fit the part required.
Jul 03, 2011 | Fedders AEQ07FBG Air Conditioner
Eee code
error code 01 reset? indoor signal sensor
Apr 08, 2011 | Fujitsu 36CS Air Conditioner
We have ducted air which cuts out and shows on the control panel where the clock is says EE.EE
When EE:EE is displayed on remotecontrol , press "Energy Save" &"Zone Control" buttons simultaneouslyfor longer than 3 secs. The error code will then be displayed on the LCD.Then write again. Thanks.
Jan 31, 2011 | Fujitsu Heating & Cooling
My air conditioner turned itself off and now the display reads EE we have unplugged it it runs for a little while then shuts itself off again
Remove the unit from the window,and dissassemble and use a water hose and clean the inside of the unit,remove all debris,this is most likely the problem.
Jul 10, 2010 | Maytag M7Y15F2A Air Conditioner
Maytag error message EE
What is the name and model number of your unit?
Jun 10, 2008 | Maytag M6Q10F2A Air Conditioner
Comfort aire A/C Rads 101-A EE light
Possible faulty control electronics. Call a repairman.
May 28, 2007 | Comfort-Aire RADS-151 Air Conditioner
Maytag M6Y12F2A Air Conditioner Logo
557 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
