Question about Technics SL-1210 Turntable
Sound noize Hi .. my name is george and i have the turntable SL - 1210MK2. For months now one of the technics has a problem with the right output chanel. It sounds like the electricity noice zzzzzzzz you know... I changed all the wires insight and the cartidge but it is still the same. We dont have the experts in cyprus to fix it, so i want you to help me in order to solve this problem before i have a problem with my health. Thanks, George Tsaousis
  • GTGEORGE Jul 01, 2008
    it distroyed the right chanel of all equipments from mixer to the speaker.
    i am very sure that the problem has to do with the turntable, because i bought new equipments mixer, applifier and the other stuff.
    President:
  • 357 Answers
Hi there
Have you tested to see if the problem is with the actual turn table or the amplifier? This could be the problem.
The problem could also be because a turn table is analog and not digital as most music players are. Analog will always have that sound, this is caused by the friction between the vinyl and the stylus (also known as a needle).
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Kind regards
Dustin Ellse
Posted on Jul 01, 2008
  • Dustin Ellse
    Dustin Ellse Jul 01, 2008
    Also, the turn table must be earthed or it will also make that static sound.
    Kind regards
    Dustin Ellse (BearWeb)
    Master:
  • 638 Answers
Have your problem solved as you have rated some1 as best solution.reply
  • 4,234 Answers
The buzzing is coming from the cartridge because of a bad ground. Check the head shell for a broken connection. With the headshell removed, you should be able to touch each of hte 4 pins. Two of them should produce a hum/buzz when touched. If the "active" one is shorted to the ground one, there should be no sound at all. If the connections look good, try a new cartridge and needle combination. Unless there is a broken ground wire inside the turntable or the cable from the turntable to the mixer, the only remaining part is the cartridge. This particular unit does not have any active electronics inside, so no capacitor problem can cause this symptom.
Keep us posted on your progress.
Dan
    Sergeant:
    Champion:
  • 230 Answers
Make sure that the mixer and amplifier you have bought is suitable to your device,check that first and also try by tuning the amplifier hope this will help you
    Brigadier General:
  • 6,966 Answers
Pls verify that it is the turntable that produces the buzzing sound and not the preamplifier/amplifier or the mixer (if you are using one). This could be verified by switching the left/right RCA plugs as to how they are currently connected. Should problem persist on the right channel, then it is not the turntable.
if on the other hand the buzzing sound moved from the right towards the left, pls try:
1. check the grounding of the turntable, not the shield of the wires but the body/chassis ground;
2. check the balance/level of the cartridge, it may be inclined in such a way as that there is more pressure on one side;
3. check the connector pins of the tine arm where the cartridge slides into;
4. check for any "bleeding" of the connector pins using an ohmmeter set to high resistance range. Must be no reading at all from any of the wires.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
  • Louie  Role
    Louie Role Jul 01, 2008
    Hi again,
    Appreciate the postback and additional information. Have you tried
    running the turntable without the cartridge/needle? If the buzzing is
    still there, try removing then the new wires that you have installed.
    Since it is a process of elimination, the point where the buzzing
    disappears would be the point of further diagnosis then.
    It it were a hum, the it is possibly spillage of the AC power supply,
    but since it is a buzz, then it is relatively high frequency.
    Cheers.
    Master:
  • 382 Answers
first wishing you a good health soon.. :) ..Please check with wires connection to the cartidge or try to adjust the position of the wires because you might be lucky and the noise might reduce..thank you!!..
    Master:
  • 726 Answers
Hey there irishdruid is correct its a failing capacitor usally happens
    President:
  • 2,712 Answers
Sounds like a failing capacitor on the right audio circuitry...
  • Swilin Sampson
    Swilin Sampson Jul 01, 2008
    Also try replacing the feedback 33uF cap around the op-amp with a lower value..This can be done at any electronics repair shop. I suggest you take in in to a repair shop for general fault finding on the board.. Could be any number of other capacitors that may be causing this issue as well.
Turntable hits bottom
then it's time for a new one, but the platter touches the underground: be smRt and replance the centre shaft, since you have an 1210mk2 and they need replacement. it's 40 euro. and you'll notice the difference after many years using an old one
Mar 14, 2014 | Technics SL-1200MK2 Turntable
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
Why is the right side of my Technics turntable dropping out and giving me a ground hum?
It sounds like a bad connection to the cartridge, perhaps even the cartridge itself.
Feb 02, 2013 | Technics SL-1200MK2 Turntable
He doesn't start anymore
I'm havin the same problem,
did u manage to work out what the fix is?
Dec 20, 2009 | Panasonic Technics SL-1210MK2 Turntable
Technics sl-1210mk2
this should help determine which one goes where but they may be the same , so it wouldn't matter if they have the same voltaage and amp. rating
Apr 18, 2009 | Technics SL-1210 Turntable
Fried my electrical supply...
hi aris tomas...1st check the fuse inside the turntable..then if its ok go to the main board  ..check the zener diode (D3)  and the transistor Q3 and Q2...the fidbk me wat hapen , if possible if you can chance it replace it..u
Jan 31, 2009 | Panasonic Technics SL-1210MK2 Turntable
The platers arn't hard and heavy any more
Have you tried swapping out the platters? Sometimes this will fix the problem. Also, although VERY RARE, make sure you were sold the right platters with your turntables. I doubt they found a pair of copy cat platters, but ya never know!
You can remove them by just lifting them up and off. There is a magnet that holds them down, so if you encounter resistance, just tap the center shaft with a wood block, mallet, or similar. Don't hit it too hard, you just want to disrupt the magnetic force, and/or loosen the platter from the shaft (which sometimes gets stuck).
Other than that, I've never heard of this type of issue, and I repair these things for a living.
- DJ PRO LAB
www.DJPROLAB.com
May 08, 2008 | Technics SL-1210 Turntable
Internal fuse
remove platter remove plastic cover main fuse is there
Jan 29, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
88 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
