Question about Nikon FE 35mm SLR Camera
Frame Counter Indicator does not go beyond the 26th and 27th Frame
Hi my wonderful FE works well but I have experienced this problem. When I am using a 36 exposure roll of film, the frame counter does not go beyond the 26 or 27th Frame Counter. Is there a problem with the frame counter. This happens even when I am using the camera with and without the MD 12 Motor drive. Need assistance to find out if its a problem with the frame counter indicator or a problem with the camera itself.
    President:
  • 2,976 Answers
Considering the age of the camera, you probably have a broken indicator gear in the top of the camera. The chances of getting it replaced aren't good. If it still works otherwise, I wouldn't worry about it. Just use 24 exposure film.
Posted on Feb 05, 2009
What exactly is numerology?
numerology is a science of calculation and predication based on formulas.
Jan 04, 2017 | Horoscopes
What is the hoLLidays business hours for the dec. 24, 25 and 32 & JANV, 1ST
usually closed 25th and 1st as both holidays, Depends on the place though as the 26th and 27th are also holidays.
Dec 12, 2016 | Cars & Trucks
CAN START ENGINE EVERYTHING WORKS APART FROM REV COUNTER NEUTRAL LIGHT AND INDICATOR LIGHT ON REV COUNTER ?
Hi, Jeremy I would love to help you but due to the magnitude of yesterday's solar flare the batteries in my crystal ball are dead and my mental telepathy headset circuitry was melted. I need the year, make, and model of your motorcycle please click on the word "COMMENT" below and provide this information in the box that will open and then click on the green comment box in the bottom right-hand corner after it posts I will receive an "ALERT" icon that will allow me to respond to your information. Good luck and have a wonderful day.
Jun 26, 2015 | Motorcycles
How to replace the front light on a lione santa fe train engine
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
Mar 14, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
Hi 03 santa fe 2.7 4wd is running rough, had the vehicle after alot of rain not capable of going over 35mph no power/compression seemed to flutter - after 5 miles stopped turned off restarted all ok - ...
Was there a Check Engine light? When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction. Once you pull/read this code, you may begin diagnosis.
Sep 10, 2011 | 2003 Hyundai Santa Fe
I recently bought a Kenneth Cole KC 3790 as a gift and I am tying to set the date...the date is presently Saturday 27th February and I am having difficulty getting to the 27th day of February on the...
Pull out crown to the time setting position (second click) and set time to 5.30 pm or am. Push crown back completely. Pull out crown to the date setting position (first click) and set it to 26th, then pull out crown further out to the time setting position (second click) and adjust watch hands forwards until the date changes to 27th. Date is changing at midnight, so, continue to adjust hands forward to the right time. Rate me, plz.
Feb 27, 2010 | Watches
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
FRame Counter does not move beyond the 26th Frame even in a 36 roll Film
Simple, the film counter unit has plastic gears underneath. the gear position or gear has worned out. simply replace the counter unit and adjust. This can be performed by any local repair shop for less than $100. -James. for further assistance email, go to www.camerarepairjapan.com
Jul 01, 2008 | Nikon FE 35mm SLR Camera
Problem of Window XP installation
usually when installation of windows fails is from more than one reason and lets hope that ur hard drive is not damaged (contains bad sectors).
try these steps :
1- use a different windows cd and a different cd rom if u can find one.
2- change the sequense of drives by changing their jumper positions and data cables ( master, slave)
3- try to clear cmos with the jumper located usually near the mainboards battery (short it for 3 seconds)
4- try ( low-level format) to ur hard drive and reinstall windows.
if the message is still seen then your hard drive could be seriously damaged.
May 28, 2008 | Intel Motherboard
Aiptek mini pencam 1.3 mega
With windows XP after installing the camera manager software, you must unplug the camera and then re-plug. It worked for me.
Jan 27, 2008 | Aiptek Mini PenCam Digital Camera
Nikon FE 35mm SLR Camera Logo
165 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
