Question about Denon Audio Players & Recorders
Hi Have a denon amp AVR 1907. How do I perform 2 activities at once, watch TV in Zone 1 and listen to music in Zone 2 for example? Thxs Steve
    Brigadier General:
  • 6,966 Answers
You are probably referring to Dual-room dual-source multi-zone (room) output feature of the AVR-1907: 7.1 CH/5.1+2 CH Independent Zone Home Theater Receiver. This feature is detailed in the advance operation pages 39 to 41 but with the use of multi source audio signal cable. Incidentally the manual maybe downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 01, 2008
    President:
  • 2,712 Answers
You can download the user manual from here:
http://www.devicemanuals.com/guidedownload/Denon-AVR-1907-Instruction-Manual-English--TmpjeE9ETT.html
Just scroll down and enetr the verification code. It should tell you how to achieve what you're looking for..
Hope that helps :)
Can i hook up two subwoofers to a denon avr 1907
Sure, just get an RCA splitter and share the Sub Pre-Out with the two self-powered subs or one amp powering two of them.
http://www.retrevo.com/support/Denon-AVR-1907-Receivers-manual/id/696ci072/t/2/
Dec 28, 2010 | Denon AVR-1907 Receiver
Zone 2 on m denon receiver will play tuner but not tv.has happened before but not sure how i fixed it
Trace your TV audio back to its source. Where's it coming from? Is there some control (volume) involved?
My $.02. You should be getting TV-related audio from its source. NOT the TV itself. TV audio componentry and speakers are bare bones basic.
May 04, 2010 | Denon AVR-1907 Receiver
Programming a Denon AVR-1907 to activate the sub-woofer
In the setup menu on your denon receiver make sure the subwoofer setting is set to ON or YES.
Feb 28, 2010 | Denon AVR-1907 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Jun 22, 2008 | Denon AVR-1907 Receiver
2 zone setup
Consult the user manual. If you don't have one, it can be downloaded free at Denon's website. Two of the speaker oututs serve multiple functions. Hookup and setup need to be checked. What you want to do is possible as long as you're only using a 5.1 setup indoors.
Sep 02, 2007 | Denon AVR-1507 Receiver
218 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
