Question about Apple iPod nano
Volume Limit How to set the volume limit? Volume has come down all of a sudden.
  • 158 Answers
On the main menu, go to settings. Then press Volume Limit. Your volume bar will appear. Move your clicker around to position the sound level where you want it.
I hope this helps. Please rate my solution.
Posted on Dec 02, 2008
  • Apple Master
  • 2,794 Answers
Press settings.
Press Volume Limit.
Move the wheel around to desired position.
Press the center button.
If you don't want to set a combination, press done.
Posted on Jul 01, 2008
Music wont turn up -- too soft to hear properly
It could be that the maximum volume limit has been switched on too low.
Go to settings then playback and then volume limit, the volume control shows the maximum volume it has been set to. Use the click wheel to select your maximum volume and then press the centre button to set the limit. Then choose done. Hope this helps.
Dec 10, 2011 | Apple iPod nano
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
I have a 6th generation iPod Nano. This is the fifth one I've had and they all have had the same problem. At some point (usually after I've had it about a month) it starts to turn the volume down...
The only thing I can think of is that maximum limit has been set low and is somehow lowering itself. To set the maximum limit
On the home screen, tap settings
Tap Music, then tap Volume Limit
The volume limit control will then come up to raise the limit move the slider all the way to the right.
If you want to stop the volume limit moving you can put in a passcode by clicking on the Lock Volume Limit and entering a passcode (I'd just put in 1234, so you can remember it easily(
Hope this helps.
Sep 07, 2011 | Apple iPod nano 3rd Generation
Remove lock from volume setting
Limit the volume Listening to loud sounds for longer than a moment can be harmful to the listener. You can set the volume level of the player to suit your preferences: 1 From the main menu, select Settings > Sound settings > Volume limit > Settings. 2 Press Vol- or Vol+ to adjust the level. 3 Press to set. > When you set a volume limit, you can no longer exceed the set volume, even if you press the Vol+ button. To enable maximum volume again, set the volume limit back to maximum or turn off, select Settings > Sound settings > Volume limit > Off.
Thanks for rating Good luck
Dec 22, 2010 | Philips Audio Players & Recorders
How to remove volume limit on eu ipod nano 5g
You can set the maximum volume limit by going to settings then playback and then volume limit. This will show you the current volume limit, use the click wheel to select the maximum volume limit and then press the centre button to set the limit. Hope this helps.
Sep 27, 2010 | Apple iPod nano 5th Generation
Wish to remove eu volume limit on ipod nano 5th generation
Go to settings then playback and then volume limit. You can then use the click wheel to select the volume limit once you have the volume you want use the centre button to set, Hope this helps.
Apr 06, 2010 | Apple iPod nano 5th Generation
When i turn up sound on i pod it automatically turns its self down
I suspect your volume limit has been set low so go to settings and then volume limit. Use the click wheel to select your maximum volume.
Nov 02, 2009 | Apple iPod classic MP3 Player
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Jul 15, 2009 | Apple iPod classic MP3 Player
How do i over-ride or reset the maximum volume limit on the nano 4g
ok maximum volume on the ipod will only work if you change it yourself. if you havent tried this yet, turn on your ipod then select settings then select volume limit and set it to whatever you want. if this doesnt work you can plug in your ipod and open up itunes and change it from there. the way you do this is right click on the song and click get info in the tabs select options and then you can set the volume limit there as well u can aplify the volume or change lower it
Jul 08, 2009 | Apple iPod nano 4th Generation
Volume is all the off and will not turn up
sound like ur volume avls(volume limit is on) so go to settings thengo to common settingsin that the second one down should be AVLS or (volume limit) contoller. also does it go up at all or does nothing happen.
Apr 17, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
Apple iPod nano Logo
588 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
