Question about Nikon FE 35mm SLR Camera
FRame Counter does not move beyond the 26th Frame even in a 36 roll Film
My Wonderful FE works well but the frame counter does not move beyond the 26th and 27th frame even when I am using a 36 exposure roll of film. This happens both when I am using the Camera with and without the MD12 Motor Drive. Any solutions or is there a problem with the frame counter.
  • gis-man Mar 27, 2009
    Hi All,
    I have solved the problem. Took the camera to a repair guy and h confirmed that the gears and counter was damaged. Goit it fixed. Thanks all for the comments and helpful suggestions.
    BRIAN REISS May 11, 2010
  • 154 Answers
Simple, the film counter unit has plastic gears underneath. the gear position or gear has worned out. simply replace the counter unit and adjust. This can be performed by any local repair shop for less than $100. -James. for further assistance email, go to
Posted on Mar 26, 2009
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
Jan 21, 2011 | Nikon N65 35mm SLR Camera
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i...
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Sep 29, 2010 | Nikon F3HP 35mm SLR Camera
On loading a fresh film into the camera the motor winds through to the last frame ie does not stop at first frame
That's entirely correct. Your camera winds all of the film out upon loading and each shot then winds the film back into the canister. Your frame counter works in countdown mode telling you how many shots remain rather than how many you've taken.
Many other camera do the same thing. The beauty of it is twofold: if the camera back is accidentally opened, then the shots already taken are safely in the film canister (except for the last shot), also when the film has finished you wait less time for the short length remaining to be rewound rather than the entire roll.
Hope this helps, please take a moment to rate my free answer.
Sep 25, 2010 | Ricoh GR-1 35mm Point and Shoot Camera
The frame counter is set on S, the film advance lever doesn't work anymore either. Is there anything I can do or should i take it to get fixed?
frame counter,mechanism is bad,before u get it fixed,try urself open the back door of the film chamber u will find a lever just below the number counter,move it freely ,push and leave, the put a dummy roll and move forward the film,if u get number counter working ok
Mar 05, 2010 | Vivitar V4000 50MM 35mm SLR Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
Frame Counter Indicator does not go beyond the 26th and 27th Frame
Considering the age of the camera, you probably have a broken indicator gear in the top of the camera. The chances of getting it replaced aren't good. If it still works otherwise, I wouldn't worry about it. Just use 24 exposure film.
Jul 01, 2008 | Nikon FE 35mm SLR Camera
Film counter does not advance when film is wound forward!
The frame counter is engaged when the film door is closed by a small tab at the top of the door near the hinge. Try pressing that area of the door as you advance the wind lever. You don't need film in the camera to do this. The counter with work without it. The door may be a little bent and not pressing the counter lever in far enough to fully engage the mechanism.
Mar 16, 2008 | Pentax ME Super 35mm SLR Camera
Frame counter-can't shoot
Having film in the camera makes no difference for the frame counter to work on this model. The counter is activated by a small tab that protrudes from the top edge of the film door near the hinge.
Locate the area on the camera where that tab meets in the channel along the top of the film compartment. There is a small opening for the lever that engages the drive gear for the counter. The opening may have debris (foam) or the tab may be broken. If neither of these is the case, the film door may be bent slightly and is not pushing the lever in far enough.
It is important for the counter to work on the FG since the metering is not active until the counter reaches '1'. (switch) It blinks 60 &125 in the display otherwise
Jan 04, 2008 | Nikon FG 35mm SLR Camera
Unlike other cameras that start at frame #1 after loading and count up as the film is used, the N55 advance the film to the last frame during the loading process. When loading is complete, the frame counter stops at the number of available frames on the roll (usually 24 or 36) and counts down as photos are taken. I know it sounds backwards but it actually makes a lot of sense to engineer it this way. After the last photo is taken (displays 1 on the counter), the camera automatically winds the end of the film into the cassette and the counter shows a blinking E. I am assuming that that is what is being displayed and not a blinking F. it it is an F, perhaps there is a problem with the LCD display? If so, it probably isn't worth having it repaired.
Jun 26, 2007 | Nikon N55 35mm Film Camera
Nikon FE 35mm SLR Camera Logo
217 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
