Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Temperature settings Sister-in-law screwed around with buttons can't find manual what are the suggested settings in the manual for freezer and fridge
    Novelist:
  • 161 Answers
I don't have any instructions for your particular model but usually you start in the middle and adjust up or down as needed. (example if lettered A B C D E start with C). Most (but not all) refrigerators have an off position on either the refrigerator or the freezer but not both. Whichever control has a definate off position controls the coldness in both. The other control just adjusts the difference between fridge and freezer. Almost all refrigerators have cooling coils only in the freezer, the fridge is cooled by blowing cold air from the freezer.
Posted on Jul 03, 2008
Hiw di I set the temp to the correct temp
turn freezer to mid point and try fridge on 3.5 as a starting point.
Keep the refrigerator temperature at or below 40° F (4° C). Thefreezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these temperatures and are generally inexpensive.
press the helpful button and check link below
Fridge temperature guide Kitchen
Jan 29, 2016 | Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
May 23, 2014 | Liebherr Refrigerators
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator and freezer temperature control
hi. thanks for te question. since you asked the question. has your fridge settled down and cooling sometimes the fridge will set itself
Sep 24, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
354 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
