Question about Canon imageRUNNER C3200 Copier
Separation pad Can you please tell me where can i buy this separation pad? it's so hard to buy something from Canon...
  • 134 Answers
Check ebay. or search for canon parts online.
Posted on Jul 01, 2008
Paper does not feed properly
If the printer is less than 1 year old, spray AIR to clean residuous of paper. If its possible clean the paper pick up roller and separation pad w/ alcohol isopropilic or soap and warm water (peace of rag or quill tip soaked in warm water. If the machine is used heavily used replace paper pick up roller and separation pad.
Oct 23, 2012 | Canon PIXMA MX320 Color USB InkJet Printer
Please check page 218 of users manual. Can you please confirm that you are looking for this part.
Paper-handling accessories
Item Description Part number
Pickup roller Pickup roller for input tray RL1-1443-000CN
Separation pad assembly Separation pad for input tray RM1-4006-000CN
You can buy it from this page.
Hope this helps. If not please refer me to the actual part you are after by referring to the diagram in the user manual.
Jul 25, 2011 | HP Office Equipment & Supplies
Paper jams every time
Have you tried printing a page from the hand feed tray ( if you pull down the front door you can feed it thru there.) take the paper out of the internal paper tray
Oct 28, 2010 | HP LaserJet 1320 Printer
Canon L75 draws all the paper at once
Try cleaning the pickup and separation rollers and /or pad inside the document feeder. If this doesnot help they need to be replaced contact your local canon dealer for help with parts.
Nov 28, 2009 | Canon FaxPhone L75 Plain Paper Laser
Printer tray mispick
need to buy a "paper separation pad kit" once you get the new pad,remove the toner cartridge and with a long phillips screwdriver remove two screws that holds the paper feed roller,remove the roller and now you have a full view of the separation pad,with a little flat screwdriver PEEL the rubber from both separation pads the old inside the printer and the new one you just got,put the new rubber sep pad in the printer and put the paper feed roller back.....printer will work as new again....
Jul 29, 2009 | HP LaserJet 3200 All-In-One Printer
The ADF takes more than one sheet at a time on the Cannon IR 5000
either something is jammed in it somewhere like a paperclip or post-it note, or the separation pad may be worn. the small rubber separation pad can be found in the hatch above the ADF, it may be possible to flip it over and continue to use it, or can be replaced easily.
The part number is FF3-3984-000
here is a photo and stockist of the part in question;
Apr 02, 2009 | Canon imageRUNNER 5000 Copier
Separation pad for HP LaserJet 4050
Open tray 1
remove the pick up roller
pad is located under the roller
in the front center of the pad is a small notch
inset a small screwdriver or key something small and flat.
give it a twist and the pad should pop out.
install the new pad by aligning with the holes and push down should sort of snap into place.
Reinstall pick up roller
Hope this helps
Mar 25, 2009 | HP LaserJet 4050 Printer
Paper sticking together when receiving a fax
There is a separation pad under the feed roller,that pad needs to be cleaned or replaced.If you open the fax and remove the cartridge,inside at the back were the cartidge was you will find a roller,cleen that roller.Under the roller there is a strip of rubber-the separation pad.Take a ruller cover it with a cloth and use it to clean the sep assembly under the roller.If the problem pressist the sepparation needs to be replaced.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Canon L80 service manual
there are no service manuals for any fax that I know of, only user manuals. You just have to take a chance and remove the covers and try to get to the rollers. ( better left to someone mechanically inclined)
here is the user manual
Jan 14, 2008 | Canon FAXPHONE L80 Laser
Canon imageRUNNER C3200 Copier Logo
53 people viewed this question
old marine
old marine
