Question about Cell Phones
Blackberry 8130 Curve Camera Troubleshooting
When I got into my camera, it says "Could not start the camera. Close other applications and try opening the camera again." However, NOTHING is open. Could you please help!!!!!
Thanks!
  • 1 more comment
  • Anonymous Jul 30, 2008
    Camera won't trun on. Says to close apllications but they are already closed. I have tryed removing the battery, turning off the phone with no help in turning the camera on!!!
  • JZ18 Nov 03, 2008
    Please help I have the same problem and I have updated all OS software and desktop manager.
  • meeshorty Apr 08, 2009
    I have the same problem with the camara on my blackberry phone. Will someone please help and give me the answer.
  • 3 Answers
I had this problem and I've tried everything posted and nothing worked so I just started messing around with my phone and may have figured it out. Here's what I did.
NOTE: I AM NOT RESPOSIBLE FOR ANYTHING THAT HAPPENS AND YOU ARE SOLEY DOING THIS ON YOUR OWN AT YOUR OWN RESPOSIBLITY. Good Luck
1. Click the Menu Button
2. Scroll to Options Icon (the wrench) and click it
3. Click Advanced Options
4. Click Applications and wait for the Apps to load.
5. Scroll down and delete the apps that you dont need (see what I deleted)
6. I first deleted ICQ Messanger by scrolling over it and selecting the menu button then clicked delete, then clicked Yes and let it reboot
7. After it rebooted I clicked the Camera button on the side and it worked after I rebooted
8. Then I went back in and deleted Yahoo Messanger and let it reboot again. (This is up to you)
9. Last I deleted Windows Live Messenger and let reboot once again. (This is up to you)
I deleted these because I didnt use them anways. These were the only 3 apps that I deleted since I never used them. If you want, you could even delete Brick Breaker if you dont play it but I wouldnt delete any other Apps other than these.
Posted on Jan 15, 2010
Thanks!
Posted on Jul 05, 2009
  • siham_viz Jul 05, 2009
    Thanks!
Thanks!
  • 541 Answers
The memory in the blackberry handheld device might be full or recently if you have installed any 3rd party applications or other application, then delete the application and then remove the battery when the phone is still switched ON and then reinsert the battery and then switch on the blackberry phone and then try to open the camera application.
Thank U.
Posted on May 26, 2009
When I got into my camera, it says "Could not start the camera. Close other applications and try opening the camera again." However, NOTHING is open. Could you please help!!!!! Thanks!
If you are verizon, call *611.
If not, then u can lick my ****
Posted on Aug 06, 2008
Blackberry camera problem
Any other program using the camera? (such as custom filters.. etc) if you have anything that is using the camera application then it won't actually close until you close the hosting program; easiest way is to take out the battery WHILE THE PHONE IS ON (important part, that's why I yelled it :) ) and leaving it out for about 10-20 seconds, reinsert and try again
Apr 18, 2013 | RIM BlackBerry Curve 8520 Smartphone
Could not start the camera. close other applications and try opening the camera agai
why is my camera not working, it is saying close other applications and try again.
Feb 05, 2011 | AT&T Blackberry Curve 8300 Smartphone
Camera ERROR MESSAGE Blackberry Curve (Sprint)
Your OS maybe corrupted so you will need to reinstall the OS, you can do this by connecting the phone to your pc/laptop using the USb cable then open the Blackberry Desktop Manager and click on the apploader then install the applications and install the OS as well as the features for the phone....
Thks
Bajan Guru
Barbados4life
Dec 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Camera wont work, wants me to close apps and try again
Sounds like you may have a corrupted java system. Try to reload the OS by going to the Blackberry.com website, an downloading the desktop manager 4.7 fairly large, as well as the Blackberry device software. Depending on Carrier it should be the 4.5 version. Install the desktop manager, then install the handset software. Plug the phone in let it detect the settings, and then use the application loader to reload the handset software. It will back up your settings, and applications, and restore them once it's completed.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
My camera on my blackberry curve is not working.
when i try to use the camera on the blackberry 8310 it tells me to close other application, how can this be fixed
Jun 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Very gently take the back off of the Blackberry, slightly push in on the camera itself, reboot and the camera should work.
I found out the hard way selling my phone on eBay only to have it returned because the camera didn't work. It's a hardware issue and not a software issue.
If it's still under warranty, try and get a new phone, otherwise --problem solved.
Feb 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
My Blackberry 8310 curves camera won't open
OMFG lol!. I just saw this on pinstack.com
My camera had hte same problem for months and this just fixed it!!
1)Remove back cover
2)Press gently, but firmly on lense (you should hear a click)
3)Battery Pull
Apparently if dropped at all, the camera can shift!!
Cheers, Imma go take some pictures after months of not being able to!
Jan 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cell Phones Logo
1,637 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
