Question about Lands Phones
Static I have two different phone types 1. an old singler unit 900 MHX which I have had for many years with no problems at all on this unit. The second unit is the DCT 746 with two phones, Until this last week have had no problems with either unit. However now when I use either the line will be clear then static comes on either phone in use... Its not the phone line because the old unit has no problem. I have cleaned the housing with a dry clean cloth...left the phones over night without use....Still the little box shows in the right had corner. I have never had a problem with any other phones... Used other Uniden's for several years without this problem. Help......
    Master:
  • 638 Answers
Either its the line problem or its the faulty unit, but as u said you have checked the other unit on the same line and its working perfect.then this is a faulty unit ,but as u mentioned it was having no problem till last week,then it would not be a major faultjust get it repaired and serviced from any authorized technician.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jul 01, 2008
    Brigadier General:
  • 6,966 Answers
Pls try checking for any new electronic/electrical device that was fairly recent (within the same time period) such as electronic florescent lamps, neon type lights or others of such type/nature. Additionally, you can try switching off other appliances, lights, devices to determine if any affects the Unidens causing the static. In some cases, it could be a neighbor's phone within the same frequency range.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Novelist:
  • 126 Answers
Hi there plz try to change the channel on the pair of dct phones there will be a button to change the channel ,also if its possible that the base station has been moved or has a new appliance or say radio been placed anywhere near the base this will cause interferance ,are the phones set to analog ot are they set to digital have a look at these options and get back to me thanks hope this helps you
    President:
  • 2,712 Answers
Must be some loose connection within the phone circuitry. I suggest you call the point of purchase and get this rectified..
New issue after a few years of good service, very heavy static on all phones in the system. It is not the DSL filter, as i tried a new one.
Is it possible that the DSL line is filtered outside or the phone jack is defective? Has anything changed recently? Try isolating the DECT 6.0 phone system. Otherwise, consider replacing it with a 5.8 GHz system. I have a the same system (the Panasonic KX-TGA402N -- the three pack, a old 900 MHz cordless answering phone, several Bluetooth devices, and a 2.4 GHz wireless router (Linksys WRT54G2.) I have no noise problem. If you can't determine the source of the interference, I assume you already replaced the phone system.
Mar 08, 2015 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
How to install MHX HS
It is my understanding that Hummingbird MHX HS is a transom mount kit. So it will depend on what you are mounting. It is likely the mount instructions are available with the transom transducer you are going to mount. Please drop a comment to clarify.
For details of all Hummingbird manuals refer to
Product Manuals
Aug 14, 2014 | Humminbird MHX-HS TM Mounting Hardware
Very bad static pn the phone
I have the same problem on all the handsets and I don't know the answer to solving the problem. I just pulled out my old phone. I give up!!
May 02, 2010 | Uniden Cordless Phone
Kango 900 demo hammer on off switch needs replacement were can i purchase parts.
what country are you in? in australia atlas copco are the distrbutors. i`m sure you can find out on the internet
Aug 11, 2009 | Hammering
Uniden cordless phone 900 MHz
A phone uses a voltage drop to determine when it is answered or hung up. What is happening in your case is the phone or base unit, or worse yet the house wiring has a short to ground somewhere. This also cause the static you hear. You can get a regular phone and plug it into the same cord and see if it works normal. If so it is not the house wiring but the phone or base unit. If so you can only hope to find the short yourself which is very time consuming and difficult on modern digital units. Sorry to say it's cheaper to get a new unit than pay for repair. The only other thing that cause those symptoms is the batteries are going dead. I assumed you checked this first. If not you can try changing the battery pack on the phone.
Mar 28, 2009 | Uniden Cordless Phone
Static-y h700
Since it is only a week old I would take it back where you bought it and tell them it is full of static and get a new one or different one.
This model is notorious for having static problems. You could also do an RMA with motorola since your unit has a 1 year warranty.
http://direct.motorola.com/hellomoto/nss/Replace_an_accessory.asp
hope that helps!
Jan 29, 2008 | Motorola Mobility H700 Wireless Headset
Background static
1. How old are you phone lines in the house?  Check the "main" terminal connections.  Clean and reconnect.  (Make note how the wires are connected).
2. The power transformers for the phones maybe you trouble also. Unplug all except the main unit.   Check each transfer one at a time. Do you have static?  One or more may be your problem.  Replace the bad ones if needed.
Oct 04, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Lots of static heard during use of this phone.
Time for a new phone. Most likely there are some bad solder connections and they could be anywhere. A 2 year old battery should not cause such severe problems so I'd spend the money on a new phone before a new battery.
Jun 27, 2007 | Motorola Mobility MA580 5.8GHz Digital...
Lands Phones Logo
77 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
