This is a firmware error. Possible causes are corrupt image file or defective firmware. Try other print files. If some work, then some are corruped. If none work, replace the firmware. Call 800-959-1575 for firmware.
There is a good possibility that you are having a hardware failure of the Hard Disk Drive, causing the windows error.
Either in the BIOS or in the F12 boot menu should be an option to run diagnostics, see if the hard drive fails. If it does, then you need to replace the drive.
If not, you will likely need an XP Installation CD so you can boot to Recovery Console and run the command CHKDSK /P to try and recover the operating system
if you are worried about losing everything on your phone just sync it up with your computer and it will save all your contacts and pictures/music so after the reset you can put them back on your phone.
