Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Power shuts off after 30 seconds
Power will not stay on, it automatically shots off after 20 seconds.
    Novelist:
    Champion:
  • 203 Answers
First, try to vacuum out the vent holes on rear of set. Lack of air will cause fans not to run properly. If that doesn't help, the next thing I would suspect is a lamp. Pull the lamp according to directions in manual or on set, then reseat it back in place and reinstall cover. But make sure not to touch the glass. Sometimes any of these simple things will cause shutdown. If all else fails get part number of lamp and replace that first. You will eventually need a lamp wheather it is the source of this problem or not. Good luck on this one, Russmann.
Posted on Jul 01, 2008
My furnace blower shuts off after 20 seconds of running
Could be a defective flame sensor and/or thermostat
Feb 23, 2018 | Heating & Cooling
DSC-HX5, Lens is Stuck in Zoom out mode. Turn On works but screen stays black. Automatically turns off after 10-20 seconds.
Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
Jul 27, 2017 | Sony Cyber-Shot DSCHX5 Digital Camera
Generac gp6500 will not stay running for more than 20 minutes.It shuts itself down then it is hard to restart and when it does start it will not continue to run. If I let it sit for 20 min. or more it will...
Here is support product lookup. Requires more specific numbers about your gp6500.
Shuts down automatically from oil shortage.
Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Jun 07, 2017 | Generac 5623 GP Series GP6500 8,000 Watt...
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Power off automatically, the red light in front of the tv blanking, remote / button can not shut off tv, only unplug the power. After 20 seconds replug the power, tv turns normal, but it happen again and...
Good Day,lizbg;
Check the solder connections at the negative side of both C809 and C810. Resolder if necessary. This a common problem with model.
Good Luck, Big Irish.
Jun 14, 2008 | Toshiba 42H81 42" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
