Question about Sharp AL 1631 Copier
PROLBEM ON MY COPIER
4 H FLASHING
  • helper5 Jul 09, 2008
    i had the same problem with the 4 H flashing - i turned the copier off and it still has the same 4 H flashing. could you tell me where the fusing rollers are? thanx - mr bbq
  • Sharp Master
  • 2,794 Answers
That has to do with your fusing rollers not being at the correct temperature during power up. Try turning it off, wait a 30 seconds and turn it on again. If the problem continues, your fusing rollers will need to be looked at.
Posted on Jul 03, 2008
My copier is displaying flashing 4 and H
press the start button (big green button) , to see the next part of the error code ,
a simple reset should be able to fix this , so depending on your copier model, and the rest of your code ..........
Aug 21, 2014 | Office Equipment & Supplies
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
HAD FOUR POWER SPIKES AND COPIER WENT OFF WITH A h
dude call a copier tech... and buy a powerline filter... this way the spikes wont affect your copier... the error is easy to fix... but you might have some damage under the hood... call a copier tech today...
Dec 16, 2009 | Office Equipment & Supplies
I have the same prolbem
sticking float on sending unit.clean or replace with new unit
Aug 27, 2009 | 2006 GMC Envoy
I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Jul 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AL-1217 keeps flashing H4 and does not respond
This is a typical fuser lamp issue. This is usually caused by a fluctuation in current supplied to the fuser assembly when the copier is warming up.
This cannot be solved by powering off the unit nor by unplugging it!
Follow the simple steps below to correct the issue:
  1. Power on the unit.
  2. When the LED display starts flashing "H" and "4", Press C and Auto button(this is the leftmost button with the copier console facing you)
  3. Repress the C and Auto Buttons again
  4. Press the copies button until 14 appears on the LED.
  5. Then Press the BIG Blue COPY button(the rightmost button with the copier console facing you)
Hurray, that's all folks
Mar 25, 2009 | Sharp AL-1217 Copier
H 4 flashing problem
H4 flashing on Sharp copiers indicates that the fuser tempurature has failed to reach temperature in a given time. The posible causes of this are 1.Failure of the heater lamp or heater lamp drive circuit. 2. Failure of the temperature sensing circuit. 3. The initial temp. of the fuser roller was very cold. or 4.low mians supply voltage for a short time (brown out). The copier does not allow a simple on/off reset of this fault because in cause 2. above the copier may overheat and cause a fire.
The reset for this model should be:
Clear ® Density select ® Clear ® Density select - 14-Print.
May 27, 2008 | Sharp AL-1642CS Copier
Copier won't print
has a bad fuser unit and may need to reset code with sim 14....
Jan 17, 2008 | Sharp AR-207 Copier
Sharp AL 1631 Copier Logo
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
