Question about IBM ThinkPad A21m 2628 Notebook
How do in reinstall the os without a disk?????????
My lab top has stop error....in accessible boot device...cant get out..keep it getting the the blue screen
    Genius:
  • 2,028 Answers
You can't reinstall the system without a disc, and a majority of the time this error indicates hard drive failure.
Posted on Jul 02, 2008
Disk boot failure insert system disk comes up when i try to start the computer
There are a number of possible causes for this; the most common is the HDD has failed (or the hardware does not recognize it for some reason) but it's also possible the OS has become corrupted which has also affected the boot loader (and any partition tables) on the drive, which can also contribute to the error. If you are prepared to lose all data, wipe the OS drive (unless you have a spare to test this theory and see if it is a hardware/motherboard related issue or just the original drive is suspect) and reinstall the OS onto it, without device drivers (just for now as you need to see if it will boot without any problems). If it does, your OS was probably corrupted and simply needed reinstalling. Then it's a matter of installing drivers, software and updates. However, if you get the same 'disk boot failure' error on reboot, then the HDD is most likely full of bad sectors which may be impossible to repair or recover - and therefore it may need to be replaced.
Apr 17, 2014 | Compaq Presario sr1403wm AMD Sempron 3000+...
Hi, I have a Dell Inspiron Mini 10v laptop and recently I have received a blue screen error. The actual message says: STOP: c000021a {Fatal Error} The windows log on process system process terminated...
First Thing I would try would be to try and boot into safe mode, keep pressing F8 (about once a second, but not too quick) after the bios screens have gone, when you get the menu then select safe mode, if it boots into this mode it is a driver issue, maybe cause by something new installed or a driver update failed. You would need to try and remove this new device via the device manager in the control panel, and remove from the computer itself.
If not this and without further infomation from the event logs, the 2nd most common cause from this is Hard Disc Corruption, this may be resolved by a wipe/reinstall of your windows OS from the recovery cd/media (you will lose all your data on the drive, you may get this saved if you go through a IT pro to do it for you), if it continues to do it, there may be a corruption on the boot sector of the drive that cant be resolved, in which case you would need to replace the hard drive and reinstall.
Jun 28, 2011 | Dell Inspiron Mini 10 Notebook
My EEE PC1015 PE keeps giving error message "Reboot & Select proper boot device of Insert Boot Media in selected Boot device & Press a Key." Also, beeps continuously for approx. 1-2 min then stops...
in situations like this you just must download the correct manual and reinstall the OS,if you have no disk choose a different OS some are virtually cost-free
Aug 29, 2010 | ASUS Eee PC 1000H Laptop
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
Feb 28, 2010 | Microsoft Windows XP Professional for PC
Reinstalling
Hard drive has bad sectors on it which is why its giving you that message even though you can go thru the restore. Normally going thru the system cd and then the recovery cd should bring you into windows with the device drivers installed.
Dec 10, 2009 | Acer Aspire 5520-5156 Laptop
BLUE SCREEN STOP ERROR AND NO HARD DRIVE SHOWING
Sorry, but there's no real way to troubleshoot this without actually having the device. The problem you describe could be anything from a simple corrupted system32 driver or MBR (master boot record), to a hardware failure. The simplest thing you could try is to boot from your OS installation CD/DVD, reinstall the OS, and re-install your applications. Next would be to re-format the boot drive and restore your data from your most recent backup. Sorry I don't have better news for you.
Aug 16, 2009 | Fujitsu Siemens LIFEBOOK S7010D...
Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access the item.
Does the PC boot up and the displaythe desktop with icons? If not try repairing the OS with the bootable original OS CD/DVD and select he repair option or reinstall the OS without formatting on the same drive/partition. If after this you can access the BIOS, keep all settings as default or fail safe option. Also run checkdisc if you can fro m the ROM.....................sodeep
May 11, 2009 | Computers & Internet
Computer Blue Screen of Death
burn this disk as an .iso and boot from disk. try the recovery options on this disk first, and if nothing then you may be in need of a free OS install. you MUST keep all virus, spyware, and firewall up to date n order to keep your computer safe. free-avg.com does have a great free download.
Good Luck
Mar 12, 2009 | Computers & Internet
Blue Screen error
Try to boot the PC without the XP Home CD in the CD drive, and keep pressing the F8 key until it comes up with a boot menu that includes a Safe Mode option.
If you had the XP Pro CD I'd suggest doing a recovery, but XP Home doesn't have that option I don't think.
You may have to try a few times until the boot menu appears. Don't hold the F8 key down - keep pressing it!
When you get into Safe Mode, right click on My Computer and choose Properties. Then go to Hardware tab (i think - not in winXP right now) and choose device manager. Just remove the Video Card from the list altogether, and then restart. Should force it to use generic video card drivers.
then check your video card model and look for the updated driver
Nov 17, 2008 | Dell OptiPlex GX150 SF PC Desktop
No boot disk error when hard drive disconnected
Are you making the disk the "master" device when you plug it in to the PC?
Nov 02, 2008 | Computers & Internet
IBM ThinkPad A21m 2628 Notebook Logo
78 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
